Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
I've been using 20/50 weight Valvoline VR1 which is a racing oil with added Zinc (for lubrication). You might also add a little Marvel Mystery Oil. I would not use Synthetic oil since the engine tolerance is not as precise as a modern engine.
2nd that on the oil with Zinc. I recently pulled the head off my Cooper S and was able to check the buckets and checked camshaft spec. with a dial indicator. I had no discernible wear on the original factory hardened camshaft/buckets which was a pleasant surprise!
Another vote here for Valvolene VR-1. 20/50.
Been using it for several years and very happy.
I would not suggest the synthetic. Might find even
more spots under your car ( just marking their territory!).
Gil. NoCal
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
