General Tech Grinding Gears in Shift From 1st to 2nd
KVH
My transmission following some adjustments and repairs is working great, but I’m getting some slight grinding from 1st to 2nd unless I slow down the process—I stop .5 seconds mid-way and then no issue.
I’m OK just doing that. But I want to ask: is the slight grinding in a fast-paced shift normal? Is it an adjustment issue at the slave cylinder (my slave plunger gap is definitely smaller than .1)? Should I just chill and keep shifting carefully as I’m doing?
Thanks all!
dklawson
If the grinding does not happen during the other shifts, it is probably a synchro problem.
Try double clutching between 1st and 2nd. The following is a brief overview in case you are not familiar with the process.
For up-shifts you push in the clutch and pull the lever out of gear and into neutral. While in neutral you let the clutch out very briefly, then immediately press it in again and select the next gear. The short pause in neutral with the clutch out gets the next pair of gears closer to matching speeds so you can select gears without grinding. The pause in neutral is very, very short. You don't have to or want to pause for a long time in neutral.
Double clutching while downshifting is more complicated. If you don't need to do it... don't. That process is similar but involves blipping the throttle while in neutral to speed up the laygear. I can do it but I never feel like I am doing it right.
TR3driver
Great Pumpkin - R.I.P
A quick test for a dragging clutch:
With the car stopped, engine idling, depress the clutch and hold it down. Shift to a forward gear, then back to neutral, still holding the pedal down. Wait a few seconds, then shift to reverse. If the gears grind at all, you've got a dragging clutch (or pilot bearing).
Otherwise, I agree, it's probably a tired synchro ring. 2nd gear seems to usually wear the fastest. Doing slow shifts sure is a lot easier than changing that ring! (And won't hurt anything as long as you don't grind the gears.)
Sarastro
I still remember that my TR4A, bought new back in the 60s, wore out the second-gear synchro in a year or two. It wasn't covered under the warranty, so I just double-clutched through life. That synchro gets a lot of use, so it's no great surprise that it wears quickly. But in your case, I'd expect a worn synchro to show more problems in downshifting than upshifting. In my experience, those grinding problems most often are clutch-related.
CJD
Brings up a good point. These are far from strong gearboxes. It is smart to do the pause shift (or double clutch if you prefer) at all times to extend the life of the synchros. After all, you aren't going to win many races with a 12 second 0-60mph time! I personally don't double clutch up, I pause. But I do double clutch on down shifts.
pdplot
I thought you were talking about the Alfa Spider gearbox. They all do that. Can't hurry that shift into 2nd or you get a real graunch. Something about the Porsche synchros Alfa used. Just take it easy or you'll wind up with a covering of metal bits on your magnetic drain plug.
Geo Hahn
My transmission following some adjustments and repairs is working great...
Did you replace the 2nd synchro as part of that? Seems counter-intuitive but in my experience a new synchro can also exhibit this behavior at first then it goes away after some use.
If you did not replace that synchro then yeah, likely just worn and slow 1-2 shifting is an easy adaptation.
KVH
KVH
I’m curious what is meant by a dragging clutch? Is that an adjustment or a wear issue? Or neither?
CJD
A dragging clutch is a clutch that does not fully release. It releases enough to allow the car to stop with the tranny in gear, but if you are stopped, it would be difficult to take it out of gear, then it turns the tranny with enough force to grind the gears when attempting to shift back into a gear.
Dragging clutch can be caused by:
1) Improper adjustment
2) Worn slave or master cylinder
3) Air in the clutch system
4) warped clutch plate, disc, and/or flywheel
5) Slave cylinder attached to the longest hole on the clutch arm
When you asked if it was a wear issue...it could be. If you get a ton of slop in the linkages, then it is possible.
KVH
KVH
Hmmm. I did relocate the slave rod to the bottom hole if the clutch arm. It seemed more “square” to the action in that location. Are you saying that could be my issue?
CJD
It very well could be. If you re-locate, remember you have to re-run the adjustment procedure.
TR3driver
There should be an adjustable brace from the slave cylinder up to a pan bolt. You can probably adjust it a bit to bring the slave square to the middle hole.
Usually, lack of travel (due to wear, wrong hole, etc) will show as the clutch engaging with the pedal very near the floor. If yours doesn't engage until the pedal is up off the floor, your problem probably lies somewhere else.
Sometimes, it can be just rust & dirt on the splines causing the clutch to drag. Driving around town (meaning lots of stops & starts) for a half hour or so might free it up.
glemon
I will add on the 2nd gear thing, my 4a had that issue too. I still remember (and this was over 30 years ago!, but now I can't remember if I brushed my teeth or put on deodorant in the morning) that if I shifted from out of first at 3000 and waited until it dropped to 2000 for second I would get a perfect shift nearly every time.
There is also a "feel" if you are sensitive with the box, waiting to avoid the crunch but the box should tell you when it is good to go. As the synchros engage you will get a little resistance, if you let the resistance win just a little (as in don't force it into gear) until the resistance gets slightly less it should engage with little or no crunch. While it is certainly nice to have strong synchros in all gears, there is also something satisfying to the art of matching revs to the box--but it does get a little dicey if you let others drive your car, as most won't be sensitive the little quirks, and the crunches are a little uncomfortable for all involved.
sp53
I thought a tr4 had a 1 inch slave cylinder? You are saying yours is smaller. If you are supposed to have I inch slave and I think you are, I would change to what it is engineered for. Many years ago I used a 7/8 slave cylinder for a tr6 on a tr3 because that is all there was available new at the time, and I had all kinds of problems. Most of which use it took a lot of force to get the clutch in and I think might ground between gears shifting. The 3 finger clutches are different and use a 1inch slave cylinder. It might be worth a try.
C TR2/3/3A Gears grinding on first startup..... Triumph 14
longbridgehealey gears grinding when shifting Spridgets 11
R Gears are grinding Spridgets 7
J Clutch and Grinding Gear Austin Healey 12
M Grinding when shifting into first Spridgets 10
T TR6 grinding right rear wheel Triumph 22
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
JPSmit What is that strange grinding sound in the distance? Spridgets 3
bighealeysource Mysterious grinding [ouch] noise on BN2 Austin Healey 7
J Transmission grinding! Austin Healey 15
Jim_Stevens Grinding wheel removal Triumph 15
zimmy grinding noise.... Spridgets 50
martx-5 Cam Grinding Triumph 4
S Grinding into first Spridgets 20
NutmegCT Starter grinding noise caused by a broken housing. Triumph 28
NutmegCT starter grinding Triumph 17
D grinding noise on 91 xjs v12 Jaguar 5
K Second gear grinding Triumph 17
S Gear Grinding in my BJ8 Austin Healey 2
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
Hamish Racing General Tech Close Ratio Gears Triumph 2
PAUL161 MGB Early B Banjo Rear Gears MG 2
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
B TR4/4A New valve gears/timing Triumph 21
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
M For Sale bj8 ring and pinion gears 3:55 for sale Austin Healey Classifieds 6
C MGB Should I lubricate the cog gears MG 2
M Wanted wanted gears Austin Healey Classifieds 0
M TR2/3/3A Tr 3A Planetary Gears Triumph 2
pan Austin-Healey 100 BN1 Gears Austin Healey 5
rjc157 3.54 crown and pinion gears Austin Healey 2
TulsaFred Timing Gears dot to dot Spridgets 9
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
Lukens TR2/3/3A Jaeger speedo gears for the odometer. Free Triumph 2
R TR6 Cannot engage gears Triumph 7
N lube starter gears? Triumph 6
BN6_2197 Gears do not engage after gearbox O/D refurbishment Austin Healey 27
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
M Lempert 3:54 gears Austin Healey 10
T Setting up the diff carrier's gears questions?? Triumph 3
M looking for rear end gears for bj8 Austin Healey 25
PAUL161 4.22 gears! MG 11
KVH TR4/4A Chips of Gears in TR4A Overdrive Triumph 2
richberman Anyone rebuild oil pump gears Austin Healey 1
TRclassic3 TR2/3/3A TR3 Timing gears Triumph 5
HAN5L778 Transmission Gears Swap Spridgets 4
Ed_K The 3.56 Lempert gears corrected my speedometer ! Austin Healey 14
