TR2/3/3A Tr 3A Planetary Gears
midnight
I can find nothing concerning the the fitment of planetary gears - I have a lot of clearance - I see where thrust washers of varying thickness are available - I don't have any idea how much to tighten the clearance - I see no size offering for the sun gears - Midnight
TRopic6
Aloha Midnight,
For the differential, there is a brief statement in the TR6 shop manual: 51.25.19.38. "Select and fit planet gear thrust washers as required to obtain zero backlash." I started with the same size TW that was in there, and ended with one size up. It's a backup and haven't used it yet. I expect clearance wears in on its own in use. Earlier TRs had the same diff innards; maybe some with actual solid axle TR experience will chime in at halftime.
Ad over - back to the Superbowl! Jeff
CJD
When I first read this post I thought Miles was talking about the overdrive...but diff makes sense too!?!
J Planetary Gear Removal Austin Healey 3
RickB Planetary Overdrive? sounds Sci-Fi... Spridgets 5
RickB Seen on Craigslist... "Planetary Overdrive"? MG 1
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
Hamish Racing General Tech Close Ratio Gears Triumph 2
PAUL161 MGB Early B Banjo Rear Gears MG 2
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
B TR4/4A New valve gears/timing Triumph 21
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
C TR2/3/3A Gears grinding on first startup..... Triumph 14
M For Sale bj8 ring and pinion gears 3:55 for sale Austin Healey Classifieds 6
C MGB Should I lubricate the cog gears MG 2
M Wanted wanted gears Austin Healey Classifieds 0
pan Austin-Healey 100 BN1 Gears Austin Healey 5
rjc157 3.54 crown and pinion gears Austin Healey 2
TulsaFred Timing Gears dot to dot Spridgets 9
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
Lukens TR2/3/3A Jaeger speedo gears for the odometer. Free Triumph 2
R TR6 Cannot engage gears Triumph 7
N lube starter gears? Triumph 6
BN6_2197 Gears do not engage after gearbox O/D refurbishment Austin Healey 27
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
M Lempert 3:54 gears Austin Healey 10
T Setting up the diff carrier's gears questions?? Triumph 3
M looking for rear end gears for bj8 Austin Healey 25
PAUL161 4.22 gears! MG 11
KVH TR4/4A Chips of Gears in TR4A Overdrive Triumph 2
richberman Anyone rebuild oil pump gears Austin Healey 1
longbridgehealey gears grinding when shifting Spridgets 11
TRclassic3 TR2/3/3A TR3 Timing gears Triumph 5
HAN5L778 Transmission Gears Swap Spridgets 4
Ed_K The 3.56 Lempert gears corrected my speedometer ! Austin Healey 14
M_Pied_Lourd Switching Gears..... Triumph 18
M Seeking 3.9 or 3.7 diff case or just gears Spridgets 3
L I'm having problems with my timing gears Spridgets 19
vette Speaking of Rear End Gears Austin Healey 20
Cookie EEK Crunching Gears! Spridgets 17
Cookie 1971 Austin Healey Sprite eek - crunching gears! Austin Healey 3
philman Wedge TR8/7 Speedo Pinion Gears Triumph 5
amcboy Question about speedo gears and about snaps... Triumph 6
R timing and replacing timing gears & chain Spridgets 12
A timing chain and gears Austin Healey 10
R Gears are grinding Spridgets 7
tomshobby Oil pump and timing gears and chain? Triumph 18
bugimike top gears Hamster on little roadsters Other Cars 4
D Bj8 higher ratio gears Austin Healey 1
