longbridgehealey
So I had two problems going on at once. I was losing clutch fluid from the master cylinder when shifting, and the gears were grinding when shifting, requiring several pumps of the clutch to shift. So I started with the master cyl, and replaced it last night. Cured the leak, but still have the shifting issue. Gonna replace the slave cyl on Monday. Any thoughts on the grinding of the gears? It can be in any gear, but does not happen all of the time in any gear. Rapid pumping allows smooth shift....
(Oh, 1969 sprite)
Thanks,
Larry
(Oh, 1969 sprite)
Thanks,
Larry
