rear wheel studs on my 1967 BJ8
Goldie
Can the rear wheel studs be replaced without pulling the hub? Are they pressed in? I know they are splined and could probably be knocked out from the wheel side but not sure if I could get a new one back in if they are pressed in. In the course of checking my brakes, I noticed that at least one of the studs had distorted threads near the bearing hub where it goes through the knockoff spline. I was able to tighten the lock nuts but would like to replace any of the studs that look thread worn while in there.
gonzo
Those rear wheel studs are pressed into the hub and should be replaced, as you expected, by pulling the hub and tapping new ones in on the bench. If lucky, the stud threads could be restored using a proper sized die.
I purchased my BJ7 while still in high school and some of my first repairs were to correct those done by the previous owner. One particular job involved filing off regular hex head bolts which were welded to the hubs, then, with hub on the bench and checking the splines were still intact, tapping in the new studs. Good Luck, GONZO
G
Goldie
I was wondering if I managed to get the stud to clear the void between the hub and the rear brake cover when removed,then I could pull the stud back into place by pulling it into place by tightening with the stud bolts. Might have to use a spacer of some sort to pull it tight. The key is the clearance to get old one out and new one in and the splines lined up.
gonzo
Goldie, my concern with removing old studs on a mounted hub is possible damage to the bearing and race from the force exerted. If the stud could be removed with some tapping, then fine. But if they need a good pounding to force them out, then that could lead to other problems. Good luck, GONZO
G
Goldie
I decided to wait until I can't tighten the lug any longer due to bad threads. So far, so good. Then I will pull the hub and replace all the studs. I wasn't sure where I could get a socket to pull that big bearing nut. The one I used before is 120 miles from here at the place I restored it. I found I can buy one from AH Spares when I decide to do it.
steveg
I don't think the lug nuts are strong enough to pull the studs into the axle flange.
If you pull the axle, you can put it in a large vice with a couple of sockets and press the studs out.
For insertion, if you freeze the studs and heat the axle in a gas grill, you can tap them in with your lead hammer.
Healey Surgeons and BCS also sell the wrenches for the rear axle octagon nuts.
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
KVH TR4/4A TR4 Rear Wheel Studs Triumph 6
D Rear Wheel Studs Triumph 1
Geo Hahn Bugeye Rear Wheel Studs Spridgets 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
C Spitfire rear wheel bearing Triumph 2
R TR6 Rear brake wheel cylinder fitment Triumph 5
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
Martinld123 My left rear wheel is locking up Austin Healey 16
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
R TR2/3/3A Rear wheel cylinders for 54 TR-2 Triumph 3
S TR2/3/3A Upholstering the rear wheel arc Triumph 3
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
D BT7 rear wheel leaking Austin Healey 25
S Locknut - rear wire wheel - torque spec? Austin Healey 15
T TR6 grinding right rear wheel Triumph 22
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
C Rear wheel bearing or other cause? Austin Healey 18
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
drooartz Rear wheel hub oil seal Spridgets 6
J TR4/4A TR4A rear wheel cylinder source Triumph 3
RickPA BJ8 rear wheel cylinder install Austin Healey 1
trotti Pulling off the rear wheel cylinder Austin Healey 11
J TR2/3/3A Interior rear wheel arch covers question. Triumph 2
R Bugeye rear wheel advice needed Spridgets 20
Mickey Richaud MGB Leak at Rt. Rear Wheel MG 6
G TR4/4A tr4a irs left rear wheel Triumph 14
steveg Shimmed rear wheel bearings Austin Healey 13
Crankshaft TR2/3/3A Noise from rear wheel. Triumph 1
J TR6 Inverted righ rear wheel [need help] Triumph 10
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
TulsaFred What holds the rear wheel and axle on? Spridgets 6
B Rear Wheel Bearing Oil Seal Spridgets 7
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
T 76 midget rear wheel cylinder Spridgets 5
regularman What is the permanent fix for rear wheel seals Spridgets 14
dklawson Spitfire Spitfire Rear Wheel Flanges-Common Problem or DPO? Triumph 7
G XKE rear wheel bearing replacment Jaguar 4
