TR4/4A Disc wheel studs front and rear TR4a irs
Richard_Brown
So after looking at the part numbers to put in studs for non wire wheels It seems there are part numbers for front and another number for the rear wheels, I assumed they were the same as I saw some suppliers listing 1 part number.
are they all the same ?
Darrell_Walker
They are different. If I recall correctly, the portion that seats in the hub is different.
TR3driver
Great Pumpkin - R.I.P
:iagree:
ISTR one has a tapered seat and the other a flat seat, but don't recall which is which offhand.
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
2 TR2/3/3A TR2 Lockheed Hubs - Disc Wheel Triumph 3
S Disc wheel optionals Austin Healey 2
steveg Booster with 4-wheel disc brakes Austin Healey 13
T converting disc wheel BN4 to disc brakes Austin Healey 12
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
AH3000MkIII Disc Wheeled car toolkit wheel brace Austin Healey 7
germanmichel Fly wheel -gear ring and clutch disc questions Austin Healey 13
R Disc wheel paint and referb MG 4
G Disc to wire wheel conversion Austin Healey 8
Brosky TR6 4 Wheel Disc Brakes for TR6 - Available? Triumph 17
Steve P. Bugeye:disc to wire wheel conversion...help! Spridgets 4
F Disc Brake Shimming Austin Healey 8
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
K Disc Brake Conversation to MK1 Midget Spridgets 2
I Bug eye front disc brake conversion. Spridgets 5
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
A Disc Brake pictures Austin Healey 1
A AH 3000 rear disc brake conversion Austin Healey 28
BJ8Healeys Disc brake piston seals Spridgets 2
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
K TR2/3/3A Brake disc? Triumph 19
NutmegCT Disc brake fun Other Cars 33
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
BoyRacer 100/6, 3000 Disc wheels Austin Healey 4
B Another disc brake question Spridgets 10
B Disc brake conversion Spridgets 12
M TR6 New clutch disc needed Triumph 2
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
K TR2/3/3A Front disc brake squeal.... Triumph 4
T TR2/3/3A 1956 TR3 with Lockheed Drums to Disc Questions Triumph 11
Jim_Gruber Steering Arms for BE Disc Brake Conversion Spridgets 1
Jim_Gruber Creative Spridgets Rear Disc Kit Spridgets 11
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
T Disc brake conversion questions Spridgets 5
Rut Cutting disc caution Spridgets 8
T 'Creative Spridgets' rear disc conversion Spridgets 6
T TR2/3/3A Hub Bearing Adjustment for TR3 w/Disc Brakes Triumph 3
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
B Clutch disc - which side goes towards flywheel? Austin Healey 8
R BJ7 Front Brake disc hitting Austin Healey 12
C TR2/3/3A Disc Wheek Size for TR3/3A Triumph 7
