Another disc brake question
Bernie H
I have the discs installed on the hubs and the hubs on the swivel axles. I bolted the calipers to the axles, but do not have the hoses connected to the calipers. When I turn the disc and hub I can hear the pads rubbing against the disc. No resistance, just a rubbing sound. Should it be like this ?
George Zeck
There is always going to be some, quite minimal. Hard to diagnose over the internet on what is too much.
I think I'd look to see if the rotor stops spinning naturally (lack of momentum) or abruptly (catching or binding) - especially if it stops soon after you spin. I know this is all subjective, but ....
B
Bernie H
Thanks for the reply. It does bring up another question: I have new hubs that use tapered bearings. How the hubs and discs move depends on how tight the nut is on the swivel axle. I have it so that I can turn it by hand with some minimal resistance, but I certainly can't spin it. Very hard to quantify I know.
Jim_Gruber
You may need to back off a flat and add shims to get to the correct tightness. With wheel on you should be able to spin the wheel and have it rotate on it's own for several revolutions I would imagine without the drag of pads being in place. Again subjective. But there is a process in your tapered bearing install instructions, if not there should be, om measuring clearance to get to the proper tightness. Shims I am told can be found in the McMaster Carr Catalog. Part Numbers, Thickness, etc. no clue but someone will chime in.
B
Bernie H
I contacted the maker of the hubs: JLHMorrisMinors in UK. The person who replied was very helpful. It seems that there is a 1mm spacer that, if needed, goes between the hub and the disc to center the disc between the caliper pads. Also the procedure for tightening the castellated nut on the swivel axle is to tighten the nut by hand, spin the disc/hub and tighten with a socket until the hub begins to slow. The thing to avoid apparently is over tightening.
Joe Schlosser
The big question is are you still using the spaces piece between the bearings.
The tightening method for the taper bearings is different when using this piece and it should always be used as it provides a stronger hub.
The method you described is not the correct one when using the spacer piece.
When using the spacer piece you need to shim the spindle so that there is zero free play when the nit is tightened down fully tight.
The hub should spin freely with no wobble
Joe Schlosser
Your old set up should have had the spacer piece. I know they are difficult to come by if you do not have a pair.
After a lot of discussions on the Production racing board everyone came to the conclusion that they were a very important part of the hub design.
The spindle is not very strong without adding the spacer. Using it with tapered bearings and shims effectively doubles the thickness of the spindle.
Even though you are not going to put the track, you are using 50 year old English steel that could use all the help it can get
nomad
Agree with the advice on using the spacers and shimming. The same technique has always been used on MGB's. When setting them up I used to use a dial indicator on a magnetic base with a known shim pack thickness. All that was needed then was to measure the free play and subtract from that reading to the correct figure. When you had that you knew how many shims to remove from the shim pack. Job done,
Kurt.
B
Bernie H
Thanks to all for the advice. I now know how to handle my problem with the hubs. My next question regards the rack.
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
D TR6 Another Newb Question Triumph 10
D Another use for a leaf blower. Restoration & Tools 1
