Another Use for J-B Weld
Healey Nut
So another project on my 62 Tri Carb was the shocks .
I would have normally sent them to Apple Hydraulics for overhaul and upgrade but with the border closed etc etc I decided to DIY them
Got the upgraded valves from AutoFarm .
Sandblasted all the bodies ready for paint and new oil/valves .
Once they were sandblasted one of the rears started to weep oil out of the casting flash line on the side , prior to sandblasting they were fine and all holding oil .
So I cleaned the weeping area with brake cleaner then mixed up a small amount of JB weld and using my thumb I applied it to the area and forced it into the flash line using thumb pressure , then I smeared a thin coat over the top .
2 days later , not a drip , no oily film , bone dry .
I don’t see why it shouldn’t be fine as there’s no pressure in the casing it’s just a reservoir for oil with a flow restriction device to control the load placed on it as the lever arm moves .
I wouldn't be comfortable with a crack in any suspension part, load bearing or not. It sounds like you're trying to convince yourself it'll be OK, but I suspect it will always be a little voice in the back of your head. It's always seemed to me that the entire shock body is load-bearing, so a weakness or flaw in any part of it could lessen structural integrity (OTH, I've never heard of a shock breaking apart) . At least, give Peter Caldwell at WorldWide Auto Parts a call or email and see what he thinks; if he thinks your repair is adequate you could rest easy(er).
red57
I agree with Bob. If you have a leak at a flash line, you have a crack and cracks don't cure themselves, they grow. Even if there is no catastrophic failure, more likely than not, it will start leaking again. In the big picture of restoring a Healey, shocks are cheap. Order a replacement set from Worldwide and move on.
Healey Nut
Healey Nut
I’m not concerned right now , it’s sitting on my bench still bone dry and it’s not a crack it’s a pinhole in the casting .
The only thing keeping the oil inside was the old dirt and paint .
As for ordering new if it comes to that I would get them in Canada as shipping items across the border is ridiculous with taxes on taxes with fees on taxes and duties along with brokerage fees and let’s not forget shipping and handling etc etc etc .
Tks for your concern guys but I won’t have trouble sleeping and really the worst thing is it will leak again but I doubt it .
Keoke
Setting on your bench bone dry is one thing actually being subjected to the stress when installed on the car could cause a failure.
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
D TR6 Another Newb Question Triumph 10
D Another use for a leaf blower. Restoration & Tools 1
C Another leak, another question... Austin Healey 20
