76 midget rear wheel cylinder
Tipsy
I discovered that my drivers side rear wheel brake cylinder is leaking. Should I replace both of them or does the "if it ain't broke don't fix it rule apply here? I'm thinking do both because I gotta bleed it anyway? What do you think?
ctually I'm thinking re-do the whole kit because this sides got some fluid leakage onto the pads so they need to be replaced. VB has a kit for rear drums on a 1500 that includes everything for under $100. SOunds like the way to go.?
Thanks!
Jeff
JPSmit
I bought the kit. IIRC the cylinders are cheap. Just do all and be done with it. I am pretty sure the kit also includes the hose that goes in front of the gas tank. Don't forget to replace it.
bthompson
+1. That definitely qualifies as a "while I'm under there" project. Take a good look at your axle seals too; if they're leaking at all, this is the best time to fix it, while your brakes are apart anyway.
T
Tipsy
Thanks everybody! I took the holding screw out of the axle and slid the axle partway out. I've never done that but thought I'd see what it was like. Anyway, got it partway out and then slid it back into place just to be sure I could. Now, I've developed a leak at that axle. Did I damage it just by doing that? I'm finishing up the brakes and wheel cylinders, just need to bleed it. But now that it's leaking I think I'll have to take Bill's advice and go ahead and replace the seals "while I'm under there".
Can anyone tell me what's involved? When I slide the axle ALL the way out are bearings or other items going to come with it? Or will it just be the axle?
Thanks again for all your help!
Jeff
Gerard
Jeff
Jeff,
As you might imagine, this question has been asked many times before. I wrote something up here months ago and I think it may also be in the tech library. You can find it on my web site in the Tech/How to section. I cleaned up some details in the version on my site a little.
https://gerardsgarage.com/Garage/Tech/rearAxleSeal.htm
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
tony barnhill Midget MkI Rear Wire Wheel Hub Spridgets 4
S 79 Midget with rear wheel noise MG 3
D MG Midget 1275 rear oil seal. Spridgets 0
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
AngliaGT Midget Rear View Mirror - What Will Work? Spridgets 1
K MG Midget rear drivers side spring sag? Spridgets 7
K General Tech MG Midget rear spring sag? MG 2
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
HealeyRick Safely Alert - Midget/Spridget Rear Brakes Spridgets 2
B Looking for rear marker light for 73 midget...just need the socket part or whole,also Spridgets 0
T 76 midget rear brake lock up Spridgets 3
RickB SWA formerly RB Midget needs rear fender flaring Spridgets 60
J Rear Springs Midget Spridgets 10
R Midget chrome bumper conversion rear corner caps? MG 1
P how to replace rear main seal in 1500 midget Spridgets 2
bcbug 76 midget rear brake assemble question Spridgets 2
M Sprite/ Midget rear end Spridgets 9
bcbug midget rear brake shoes adjusters Spridgets 4
M Midget Top - Rear Window needs help Spridgets 2
C Need info on gearbox and rear end oil for midget Spridgets 5
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
J Rear side marker lamps-79 midget Spridgets 9
tony barnhill '63 Midget Rear End Spridgets 39
B RX7 Rear End in a Midget Racing 3
G 1967 Midget rear end leaks oil Spridgets 12
drooartz Wheels w/o rear axles, or a Midget dolly Spridgets 1
M rear mont holes on a 76 midget Spridgets 25
Gearhead Rear disc brakes on a Midget Spridgets 2
A Need Rear Bumper for 76 Midget Spridgets 4
77_MG_Midget 77 midget rear shock conversion Spridgets 2
R rear axle search for 79 Midget Spridgets 7
R 79 MG Midget rear end tragedy MG 10
B Midget rear lowering springs Austin Healey 0
B Midget rear lowering springs MG 2
nathandarby67 Swapping rear hub on a Midget MG 7
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
