Sprite/ Midget rear end
mmotors
Anyone have a good idea of the torque (ft. lbs) for the rear differential flange pinion nut? I understand the idea of pre loading the bearing, but once its in the car with axles installed it seems impossible to set. Any good rule of thumb torque? I know the Big Healey manuel states no more then 140 ft. lbs. Thank you, Shawn
nomad
You need to make up a tool to bolt to your pinion flange to hold it. I used a 1/2 by 1 1/2 flat drilled to fit 2 holes and ground out in the middle to clear the socket you are using to tighten.
KA.
jlaird
Noop, was designed for that load.
nomad
Geeez, I went to all the trouble of looking up and copying "MG special tools"!! Oh well, its handy.
KA.
fordtrucks4ever
Make sure you check preload of the pinion bearings as it approaches required torque.
M
mmotors
It is impossible to do while in the car with the axles in, right? From my understanding you measue the resistance it takes to turn it. With the axles in you couldn't get a true measurement.
G
mmotors said:
Actually I just put on the E-brake.
Don't do it !!!! I tried it that way and the flange started turning but the axles didn't budge. I could feel "something" start to twist, you know, that strange feel a bolt gives you just before the head shears off. I had both axles out and they looked o.k. I might have a bit of twist on the pinion. It definatly started to give somewhere. I made almost a full 1/2 turn and none of it was slack. Bigger cars, yes you can do it, on these I wouldn't.
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
Mick2me For Sale Various MG Midget/Austin Healy Sprite parts for sale [approx 1964] UK only Spridgets Classified 4
Mick2me For Sale Various MG Midget/Austin Healy Sprite parts for sale [approx 1964] UK only MG Classifieds 0
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
DrEntropy For Sale Midget/Sprite carb set Spridgets Classified 0
L For Sale 1961-1969 AH Sprite, MG Midget Chrome bumpers & hardware Spridgets Classified 0
RickB Not a Midget or Sprite, but I know this car and so do some of you Spridgets 5
anarchy99 sprite/midget top interchange Spridgets 2
Gray_Cat Project Sprite & Midget in Riverside CA Spridgets 0
jollyroger Black seat kits for 62 sprite/midget Spridgets 6
A Sprite-Midget Club USA Calendar: Send Me Your Pic Spridgets 9
A Sprite-Midget Club USA Calendar: Send Me Your Pic Austin Healey 1
PSJ Midget Mk I/Sprite Mk II hardtop available Spridgets 14
scoutll The Original Sprite And Midget Spridgets 8
B 2011 Sprite-Midget Club USA Official Calendars!! Spridgets 1
John_Mc Midget/Sprite sighting... Spridgets 0
S Midget and Sprite combo MG 5
C a TON of midget and Sprite parts!!!!! Spridgets 5
P Midget/Sprite Craigs List Seattle Spridgets 4
chrpark Mk II Sprite/Mk I Midget Door hinges Spridgets 1
G Should it be a Midget or a Sprite? Spridgets 14
v8mgbal Fake 69 Midget/ Sprite? Spridgets 3
Ohiobugeye Bugeye vs. Sprite Mk2 / Midget Mk1 Starter Cable? Spridgets 20
lbc_newbie 1275 Midget, Sprite Timing Tape Kit Spridgets 2
RickB Seats Sprite Mk II / Midget Mk I [yes, again] Spridgets 23
bighly WTB 3.9 diff for Midget / Sprite Spridgets 13
RickB Need seats & steering wheel MKII Sprite/MKI Midget Spridgets 47
RickB Now I have a Sprite and a Midget!!! Spridgets 23
M Bugeye bonnet mounted on later sprite or midget? Spridgets 21
RickB Seattle - red 76 Midget $600 / Portland 62 Sprite Spridgets 11
NASpecMGB WTB Midget/Sprite orig shift knob, 1971 or earlier Spridgets 2
Biff Sprite Jubilee 2008 Give-Away-Midget/Sprite Spridgets 4
John Moore Bugeye v. Sprite MkII/Midget MkI Seats Spridgets 4
vping Midget\Sprite parts for sale. Spridgets 14
P Sprite and MIdget 50th celebration 2008 help Spridgets 21
K Sprite/Midget synchromesh Trans ? Spridgets 3
Tullamore Dash turn indicator. Sprite MK III Midget MK II Spridgets 1
J cleaning out sills Midget/sprite MG 0
captobvious Sprite/Midget steering wheel nut Austin Healey 2
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
