TR6 Rear wheel bearing help TR6
ichthos
Hello,
Well, I started out thinking I would just be putting in new springs in the rear end, and I have ended up pretty much rebuilding the entire rear suspension at this point. The last thing for me to evaluate is the rear wheel bearings. How do you determine if they need replacing? They do seem to turn smoothly. How hard is it to replace the rear bearings? I am a novice - I replaced rear wheel bearings on a 65 Ford Falcon before, but everything on this car seems more difficult. Is this something a machine shop or mechanic should do? Any suggestions would greatly be appreciated.
Kevin
TR3driver
Great Pumpkin - R.I.P
IMO if they are smooth and have no play; leave them alone. Changing them is a LOT worse than your Falcon ... I wouldn't even trust a shop unless they had significant experience with TR4A-6 rear hubs AND could show me their purpose-made hub puller. The hubs have a "locking taper" fit to the stub axle, which can easily be so tight that just sticking them in a press will distort and ruin the hub. The proper puller supports the face of the hub so it can't distort.
poolboy
What Randall said. I even bought the tool to break the hub down, thinking one day...one day I'd be faced with that task. The more I learned about it, though, I decided to pick up 2 hub assemblies, one from Ebay and the other from a 6-Pack member. Both seem ready to go. I may put the disassembly tool up for sale.
Norton47
Kevin
I have a home built tool and have used it to rebuild both my rear axles. It is not a job for the fainthearted. I have unit I bought on ebay that is disassembled that I was going to rebuild then install and rebuild the one I took off. I ended up just rebuilding both of ones on the car as they were the original ones.
Heres 2 articles.
https://members.visi.net/~kohout/rearhub.html and this one www.geocities.com/michelotti_tr/Hub_Puller_Use_Notes.pdf
The last is a pdf file and this is the one I built the tool from.
I also have a machinist drawing of the tool. PM me and provide and email and I will send it.
There are 2 things that are challenging, one it does take a big wrench and cheater bar and as the article states a car. This gets it apart. The second thing is reassembly, as it uses a crush distance piece to set the end float. Over crush it and you start over.
I still owe you a visit, between some trials and tribulations with my car and my work schedule I just haven't had time.
You are welcome to use the tool or if you want pull them off and bring then over, we can rebuild them here. There is the possibility that we can't get them apart as time, heat and rust can play a part. On the other hand all three I have tried did come apart.
Heres another post also
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/263290/1
Hope this helps
Mark
TR3driver
That reminds me, I have a copy of an article written some years ago by Eugene Wellenstein about how he made his own version of the puller using heavy pipe flanges and an assortment of other hardware. Seems like massive overkill, but depending on what tools you have available, it might be easier to build than Tony's "beast". And it only requires a picnic table instead of an Oldsmobile
I got Eugene's permission to put it on a website but never got that done ... PM me if you'd like an email copy.
There is also mention of another type of puller at
Stag Phorum that sounds intriguing. That's what I'll try first, when the time comes.
I
ichthos
Thanks for all of your help. I downloaded the info, but I have decided to take your advice, Randall, and not attempt this. I'm going with "If it ain't broke, don't fix it." Mark, I sent a PM.
Thanks, Kevin
DNK
Mark if your going his way someday. Let me know.
C Spitfire rear wheel bearing Triumph 2
C Rear wheel bearing or other cause? Austin Healey 18
B Rear Wheel Bearing Oil Seal Spridgets 7
G XKE rear wheel bearing replacment Jaguar 4
M Rear wheel bearing Spridgets 4
GBRandy Wedge TR8 rear wheel bearing noise / replacement Triumph 5
M Rear wheel bearing packed with grease? Austin Healey 5
Luke_Healey Question about rear wheel bearing seals Spridgets 11
jmwuva05 Rear wheel bearing removal Spridgets 3
N TR6 TR6 Rear wheel bearing Part #'s for timken Triumph 5
RobSelina Rear wheel bearing discussion Spridgets 30
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R TR6 Rear brake wheel cylinder fitment Triumph 5
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
Martinld123 My left rear wheel is locking up Austin Healey 16
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
R TR2/3/3A Rear wheel cylinders for 54 TR-2 Triumph 3
S TR2/3/3A Upholstering the rear wheel arc Triumph 3
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
D BT7 rear wheel leaking Austin Healey 25
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
T TR6 grinding right rear wheel Triumph 22
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
G rear wheel studs on my 1967 BJ8 Austin Healey 5
drooartz Rear wheel hub oil seal Spridgets 6
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
J TR4/4A TR4A rear wheel cylinder source Triumph 3
RickPA BJ8 rear wheel cylinder install Austin Healey 1
trotti Pulling off the rear wheel cylinder Austin Healey 11
J TR2/3/3A Interior rear wheel arch covers question. Triumph 2
R Bugeye rear wheel advice needed Spridgets 20
Mickey Richaud MGB Leak at Rt. Rear Wheel MG 6
G TR4/4A tr4a irs left rear wheel Triumph 14
steveg Shimmed rear wheel bearings Austin Healey 13
Crankshaft TR2/3/3A Noise from rear wheel. Triumph 1
J TR6 Inverted righ rear wheel [need help] Triumph 10
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
TulsaFred What holds the rear wheel and axle on? Spridgets 6
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
