TR6 Clutch problem not solved
pdplot
After replacing master & slave cylinder and flex line and two weeks of joy, the same problem has arisen. I have to pump up the clutch several times to be able to get it into gear. In addition, it is shifting hard, almost like you are shifting without the clutch. With engine off, the shift lever moves freely - like it always has. No problem ever with the gearbox. The fluid in the M/C is still at the top so no leaks. I plan to try an experiment tomorrow - start it up in gear - in reverse of course, in the garage, with my foot all the way down on the pedal. If the car moves, it will prove one of two things - either the hydraulic system is not working at the slave cylinder or the clutch disk is stuck to the flywheel. I told the shop to install the slave with the bleed screw on the top and the pin in the middle hole as recommended. Is there something else I should be testing and how do I know which it is? This is very discouraging, especially after over $600 worth of work.
Madflyer
Not a uncommon problem. Replacing Master and slave is OK also. So now that is done no reason to go backwards. You now have all new. Your master cyl is one inch bore slave is 3/4 bore. So one inch of travel equals one inch plus slave travel. this is what it takes to release clutch. If you have any play in rod, pin, or free play at peddle you lose the one inch. pumping says air in slave so bleed again. If you move to top arm hole and is better you have covered up problem so find the problem as top hole makes for stiffer peddle. With the bleeder on top as required hard to get to and some air may remain.. Madflyer
P
pdplot
No ramps. But this am, I started car in reverse with clutch pushed in - nothing. No motion. I then tried shifting with engine running. Everything normal. You'd never know there was any problem. I'll let car sit for a week and then try it again. If clutch sticking after sitting, then I'll know. Its also possible that travel isn't enough to release clutch. How much should it travel and can you see it move or is it all internal?
poolboy
When the clutch pedal is pushed to the floor, the tip of clutch shaft arm with the 3 holes should swing to the rear about 5/8 or 3/4 of an inch..not much.
The reason I asked about the ramp, I was going to suggest a way to bleed the slave if you need to again.
Just elevate the front of the car a bit and if it's on top just barely open the slave bleed nipple....you just want a drip, not a stream because you'll be back watching the level in the master cylinder and you don't want it to drain too fast...Let the level drop about half way, then top it up and let it drop one more time half way and top it up again,
If you're alone get ready to lay back down and close the nipple.
When you get back up, top up the master again.
That should take care of any air.
P
pdplot
Thanks. I'll let it sit about a week and try it then. I can jack up the front and put stands on both sides of the frame. Laying underneath will not be fun but my wife will be instructed to keep filling the M/C as it goes down. I'll make sure I have a rubber hose to attach to the bleeder.
poolboy
I know a lot of people do stick a hose onto the bleeder nipple, but I don't. I can see if air burps out of the nipple better without one.
T Sqeeling Clutch Problem..SOLVED Triumph 2
Govtslug TR6 Clutch Problem Triumph 21
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
MKIII_Joey Clutch Problem Austin Healey 5
M BJ8 Clutch Problem Austin Healey 4
T TR4/4A clutch problem on brand new TR4a Triumph 6
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
G MGB Clutch problem MG 7
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
aeronca65t Clutch pedal problem- 1275 race car Spridgets 12
M Clutch problem, a little different than usual Spridgets 8
U Spitfire Help - Clutch Problem on the Road! Triumph 11
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
J Clutch Problem - Seeking Input Austin Healey 4
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
G TR6 TR6 Clutch Problem Triumph 22
aeronca65t Common problem-clutch pedal Spridgets 2
smaceng Clutch Problem Jaguar 3
D TR6 New poster, TR6 clutch problem Triumph 10
Jims71TR Clutch Problem need Help Triumph 14
tahoe healey clutch problem Austin Healey 14
F TR6 triumph tr6 clutch problem Triumph 14
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
AngliaGT Clutch Problem Other Cars 9
TR_JOE250 Spitfire Spitfire clutch problem Triumph 22
F 67 austin healey 3000 clutch problem FORUM Navigation Questions 0
F 67 austin healey 3000 clutch problem Austin Healey 20
RickB Clutch problem this morning MK2 Sprite Spridgets 4
M A possible problem with the clutch Spridgets 8
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
A TR6 TR6 Clutch Problem Triumph 11
J T-Series clutch problem MG 13
F Frogeye clutch problem Spridgets 10
R Clutch Sticking Problem Austin Healey 4
Brosky Typical, but lucky, nice day problem [Clutch] Triumph 13
Sarastro Yet another odd clutch problem. Spridgets 5
Brosky TR6 TR6 Clutch knocking noise problem [not mine] *DELETED* Triumph 2
simpzimmer Found the Clutch Problem Triumph 1
simpzimmer Clutch Problem Triumph 1
DerekJ Clutch problem - I think! Austin Healey 14
B Do I have a problem with My New Clutch ???? Austin Healey 3
M TR6 76 TR6 clutch problem Triumph 3
G TR6 TR6 Clutch Problem Triumph 5
MattP T-Series Clutch Problem? MG 3
EMGEBE T-Series Is this a clutch problem? MG 2
