Yet another odd clutch problem.
Sarastro
Odd clutch problem in my 60 bugeye.
1. After driving the thing at engine speeds above 3000 RPM, more than a few seconds, the clutch pedal gets "hard"--that is, I start to feel resistance at a point quite a bit higher than normal. Very little play left, if any.
2. When I push on the pedal, the clutch releases normally, but when I let it out again, it engages close to the floor, a little closer to the floor than the point at which it normally engages. It also feels somewhat lighter than normal.
3. After running a half minute or so at lower speed, it all seems normal again.
It seems like, at high speed, the fluid is getting pushed back into the master cylinder from the slave. Then, when I push on the pedal, it doesn't all get pumped into the system. (I'm not suggesting that this is what's really happening; but this is the way it seems to feel to me.)
Now, it may be that this is just the way bugeyes are. If so, fine, but I just don't have enough experience with these little puppies to know. So, I have to throw myself on the mercy of you guys who really know something. Thanks in advance for any comments you may have.
Sarastro
Sarastro
Forgot to mention--the car was recently restored (less than 1000 miles on it) and both the master and slave cylinders were rebuilt at that time.
jlaird
I think it needs blead well. Restoration or not.
Sarastro
Sarastro
Thanks. I'll do that and let you know what happens. I'm travelling for the next two weeks, so it might be a while before I can get to it.
From what I've read in searching the forums, it seems like the clutch hydraulics are tricky to bleed. Well, we'll give it a shot....
spritenut
I think the master push rod needs to be adjusted.
If the pedal gets harder after some use, the rod is not letting the fluid return properly in the master.
It may just need a bleeding, if that doesn't do it, check the master push rod or shorten it just a tad.
pkmh Yet Another Oil Question! Austin Healey 8
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
PC yet another Opel Spotted 0
blumagnet yet another Flame Thrower conversion Spridgets 4
Geo Hahn TR2/3/3A Yet Another TR3A Slave Cyl Question Triumph 4
Jim_Newman Yet another muffler question. Austin Healey 3
RickB Yet Another Spridget on Seattle Craigslist Spridgets 2
Sarastro Yet another super-cheap Spridget! Spridgets 8
T TR2/3/3A yet another TR3 steering box question/hone? Triumph 9
W Yet another yellow steering arm Spridgets 1
T TR6 Yet another TR6 post Triumph 5
Dave Richards Yet Another Tire Size Question Austin Healey 11
Sarastro Yet another alternator conversion Spridgets 10
Bret Yet another sneak peek into the.... MG 13
Bret Yet another Zenith Stromberg replacement choice MG 6
Camshaft Yet another Saab Shelby wheel question[s] MG 14
angelfj1 SORRY - YET ANOTHER TIRE QUESTION Triumph 2
W yet another BMH trust certificate question Austin Healey 5
coldplugs Yet another mystery car Other British Cars 31
B Yet another road trip. Spridgets 16
MrPandy Yet another gauge question Triumph 9
catfood Yet another new Healey Austin Healey 2
coldplugs Yet another mystery car photo Other Cars 17
BritBox Yet another TR clutch issue Triumph 24
M TR2/3/3A Yet another TR3 question... Triumph 3
G Yet another Ebay rarity Triumph 10
Nunyas Yet another choke inquery... MG 8
B Yet another Newbie MG 17
Webb Sledge Yet another Triumph question Triumph 4
UltimateQuestion Yet another Miata-based counterfeit Other Cars 8
Johnny Can I add to an article that I've completed but not yet published? FORUM Navigation Questions 2
doc50 TR2/3/3A DIDN'T BLOW the OD up [yet] Triumph 6
G TR4/4A Anyone know if this car has sold yet? Triumph 0
jhorton3 Best MG Drive Day Yet Spridgets 0
B Second picture. I don't quite get this yet Triumph 1
JPSmit Is it Halloween yet? Spotted 9
jlaird Got your attention yet or Spridgets 11
T TR2/3/3A Tush - TR3a louvres or not? Color picked out yet? Triumph 15
T Yet one more bushing question - which to order Spridgets 4
charlie74 tansmission question [not problem, yet] Triumph 14
T block prep progress-slow and not finished yet-pics Triumph 3
Sherlock A Sunbeam, but yet other British cars... Other British Cars 14
2wrench Simple yet important engine timing questions Triumph 11
regularman Shortening the list of things yet to be done. Spridgets 14
Brosky Are you signed up for a "subscription" yet?? Triumph 92
budk1953 Running, but not singing - yet Spridgets 3
Trevor Jessie I don't know if has been mentioned yet... MG 0
fmichaels not stumped yet .. but Spridgets 26
jlaird Tony you do it yet. MG 6
F Someone have new floorpans not installed yet??? Spridgets 5
