TR2/3/3A DIDN'T BLOW the OD up [yet]
doc50
Everything I've heard about the A type OD is that one NEVER should back up with it engaged. I've screwed up several times and gave myself the dope slap afterward.
The other day I was on a gravel incline and spun the wheels backing up for about 10 seconds....when I suddenly realized I was still in OD.
Any comforting thoughts as to why I didn't 'window' the OD...or is that just another urban myth? If it's true, is there any forewarning just before it spirals in?
Thanks for any feedback.
Thom
1959 TR3
#TS34909L(O)
CJD
I don't think it was in overdrive. If your shifter interlocks are working, it should drop out as soon as you come out of a forward gear, irregardless of your cockpit switch position.
If your interlocks are bypassed or broke, then your roller clutch is worn out.
TR3driver
Great Pumpkin - R.I.P
Exactly. The interlock switches prevent the OD from being engaged in reverse, regardless of where the dash switch is set. There is a distinction between the switch being "on" and the OD actually being engaged.
The problem is definitely not an urban myth, but it (mostly) only applies when there is some malfunction, like the OD clutch is stuck in overdrive. The warning sign (if you are stopped or nearly so), is that it feels like you're trying to back over a curb. Pretty obvious (IMO) that there is a problem. The real danger is if you are already moving backwards and the OD engages (as might happen with a bad switch or shorted relay but no pressure in the OD before you started backing up).
The only scenario that I've found, that doesn't involve some sort of previous failure, is stopped at the top of a steep hill with no pressure in the OD. Turn the switch on, select a forward gear (so the OD solenoid pulls in), then roll backwards down the hill. As the OD builds pressure and starts to engage, it will try to stop the car abruptly. If it fails, BANG goes the sprag clutch (and probably the rear housing as well).
Geo Hahn
The other scenario I have pondered is that in a 180° spin the drivetrain can be abruptly forced to rotate backwards.
The traditional mantra -- "In a spin, both feet in" -- would possibly save the day.
TR3driver
Actually, I think that would make it worse. With the clutch out, the engine is going to keep the drive line from turning backwards. But with it in, if you got traction while moving backwards, it could force the OD to turn backwards.
Good point though, I hadn't thought about spinning out and potentially getting traction while moving backwards. I wonder though if the locking effect wouldn't just keep the tires sliding and save the OD that way. Don't think I'll try it to find out!
Likely doesn't matter though, if you're that badly out if control. If sacrificing the OD keeps me off the wall or another car, I'd call that a win!
doc50
doc50
Thanx, all. The system is all newly redone so I'll not worry so much if I forget to flip the OD switch down. No more dope slaps for me.
(Randall, I'm really liking the hard top!)
Thom
TR3 #TS34909L(O)
TR3driver
Glad to hear it, Thom.
P Things you didn't know about your car Other Cars 10
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
HealeyRick Why Didn't I Think of This? Austin Healey 15
K General Tech Why did MGB's come with oil coolers but Triumph's didn't? Triumph 17
PC didn't spot a 911 or a Javelin but did see a station wagon Spotted 1
S TR6 First drive in the TR6 went well...until it didn't Triumph 9
Lin Didn't realize ethanol had been available commercially for so long! Austin Healey 4
Steve Didn't Basil have one of these? Other British Cars 2
DNK And he didn't even stop! Spotted 18
stretchit2 Oh No I Didn't or the Dropped Not Blues Austin Healey 6
K Brake pedal doesn’t move mcylinder didn't fix Triumph 7
T I bet this didn't help its handling Triumph 9
T OK guys - I didn't buy the Quattroporte but... Triumph 29
T TR4/4A TR4A didn't use an exhaust manifold gasket? Triumph 5
Moseso I got exhausted -- at least I didn't get hosed. Triumph 7
C Today's Healey drive didn't happen Austin Healey 2
RickB Carpet - PO apparently didn't like glue... Spridgets 19
JPSmit did I mention I didn't take enough pics? Spridgets 1
jsneddon Scam - didn't somene here run into this too? Triumph 3
Mio I didn't think it was possible but.... Spridgets 21
timbn2 @$!&^%#*!!!!!!!!!!!! Why didn't you tell me... Austin Healey 10
B the picture I didn't take... MG 2
YankeeTR Yeah...I know I didn't need another sidescreen TR. Triumph 8
S New old car for me [& wife didn't even complain!] Other Cars 26
gsalt57tr3 I didn't drive it today, but maybe by the weekend Triumph 22
KLUTZ I didn't gap... What could happen? MG 14
gsalt57tr3 Didn't know the car, but recognized the motor... Triumph 13
ChrisS Jack - Just be glad you didn't buy my car Spridgets 16
Mickey Richaud Why Didn't I Think of This? Other Cars 9
TNMGB Gas pressure in tank?? Didn't happen before... MG 17
P Didn't like that fender anyway Triumph 2
philman [sigh] I didn't make it home Triumph 12
bluemiata90 Purchase that didn't get away, but... Triumph 1
Basil Tony - I didn't make it MG 1
Basil Spitfire So THATS why my Spit didn't seem peppy! Triumph 10
H blow by oil pressure causes oil to leak out of the dip stick tube. Austin Healey 12
sundown TR6 1973 TR6 blow by or leak? Triumph 6
B TR2/3/3A Down draft tube blow by Triumph 5
ttrotter 67 BJ8 Blow by question Austin Healey 12
W bad oil blow-by Triumph 19
K TR2/3/3A TR3 front suspension blow up pic? Triumph 6
G I my engine fixing to blow........................ Triumph 9
roscoe Don't want to blow my top. Austin Healey 4
G Why did I blow out 2 rheostats in 1 week? Triumph 13
B Blow or suck? MG 24
J Blow-by questions Triumph 11
J Blow-by Boy has more data Triumph 6
J Definition of 'blow-by'? Triumph 12
