Brake pedal doesn’t move mcylinder didn't fix
ken941
I was told when I got this US 1976 Spitfire it needed a master cylinder because pedal was stuck. I removed it and it's fine what should I look at next?
TR3driver
Great Pumpkin - R.I.P
Which is fine, the pedal or the MC? If the MC, how do you know?
TR3driver
:iagree:
They could even be stuck if it hasn't sat for long. The rear brakes on my Stag had apparently been frozen longer than the PO had owned the car, and he even drove the car to VTR 2006 that way.
TomMull
Check or replace the rubber hoses too. They can mimic a frozen cylinder or caliper as they tend to start coming apart internally ofter 30 or so years. Tom
F Excessive Brake Pedal Travel Austin Healey 3
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Sopwith_Camel MGB pulsing brake pedal MG 10
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
bighealeysource Soft Brake Pedal Austin Healey 7
S Receding Brake Pedal Austin Healey 32
K Midget Brake Pedal Question Spridgets 2
D TR2/3/3A clutch/brake pedal question Triumph 4
steveg "Sticking" the brake pedal Austin Healey 3
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Michael Oritt Brake pedal contact or mercury switch Austin Healey 19
H BN1 Brake Pedal Hitting The Downpipe Austin Healey 9
Gearhead_Garage Brake Pedal Feel Austin Healey 24
R Low Brake Pedal Austin Healey 9
Joe_Healey Brake Pedal Rod Painted or Natural Austin Healey 14
T TR2/3/3A soft brake pedal on TR 3 Triumph 5
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
H TR4/4A Soft Brake Pedal Triumph 3
PatGalvin TR2/3/3A Brake MC Bracket and pedal assembly install Triumph 24
angelfj1 TR5/TR250 Brake Pedal return spring Triumph 2
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
eschneider machine gun brake pedal Other Cars 3
T Soft brake pedal on BJ8 Austin Healey 3
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
W TR6 TR6 brake pedal drip Triumph 12
C brake pedal to the floor Austin Healey 6
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
CJD Brake/Clutch pedal adjustment Triumph 29
J Brake pedal cover removel? Triumph 5
J Brake/clutch pedal frozen Triumph 18
livinginthepast Disc brake conversion - soft pedal Spridgets 8
TR4 Brake Pedal Travel Adjustment Triumph 18
S BN1 clutch and brake pedal bracket Austin Healey 3
go_inbroke Brake pedal Triumph 12
N Brake pedal to the floor Austin Healey 13
Thor Brake light, do you have to remove pedal box? Spridgets 2
LuckyLuke 100-4 brake / clutch pedal seals not available Austin Healey 3
D No play in brake pedal - what a drag? Triumph 7
Randy Harris Brake Lights Work Only With Heavy Pedal Pressure Austin Healey 12
B gas, Brake, Clutch Pedal covers? Spridgets 8
saabmp3 weak brake pedal Spridgets 5
J Newbie - Soft Brake Pedal Spridgets 14
B XJ12L 1975 SOFT BRAKE PEDAL Jaguar 11
AUSMHLY brake pedal push rod adustment - YIKES ! Austin Healey 9
tr6web TR6 TR6 leaking at brake pedal Triumph 12
W Mystery of the re-occuring soft brake pedal Austin Healey 10
6 Brake Fluid Spridgets 4
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
