OK so I thought bleeding the brakes would be easy. During the fall it seemed the brake pedal would get soft and I had to pump up the pedal. No big deal. Now, since it was winter I had time to inspect the brakes and replace what looked suspicious. Sounds easy right! Never, with this car! I will spare rhe details but I went from rear wheel cylinder kits ($) to new rear wheel cylinders ($$$), rear axle seals, one brake line since the connection was completely mangled after I ended up going to vice grips.
Now after multiple bleeds (3 or 4), I still have a pedal that needs to be pumped up. By the way, every time I have re-bled the lines I get most of the air bubbles from the 2 rear wheels. The clutch cylinder has produced a fair amount of air also.
The new rear cylinders are dry. I don't see any dampness at the front calipers. All the line connections look dry - old but dry. I even pulled off the brake and clutch dust covers at the pedals; they look dry from that side.
I also bled the clutch cylinder. The one place I found dampness was along the brake line that goes from the front to the back of the car. Of course, there is a lot of oily crud under the car anyway. I didn't think a brake line would likely spring a leak along a straight portion of the line. What have I missed?? Any advise would be appreciated. I like working on this car but this is getting ridiculous. It's time to move on to some other problem.
Thanks,
Bill L
BT7
Cumberland RI
Thanks,
Bill L
BT7
Cumberland RI
