Most likely...your master cylinder is toast! Crawl under your dash, pull back the rubber dust boot on your brake master cylinder and check for leakage there! Needs a rebuild kit! And while your at it, you may as well rebuild the clutch master as well as long as the carbs are off! Michael, IL.
