John Kuzman
Greetings!
I recently took title to a '59 Bugeye (BE). The BE had been sitting for about two years. While driving the BE off the trailer, I noticed the brakes were not the best (firm pedal, but poor stopping power). After sitting for a few days, I noticed brake fluid near the RF tire. Pulled the RF drum and had soaked shoes.
I decided to re-build the front brakes. Installed new wheel cylinders, shoes and flexible hoses. Had the drums turned to within spec for max. diameter.
Bled the system using the two-person pump, hold, bleed method. Started RR, then LR, RF and LF. Each wheel several times. Using DOT 3 fluid. Bled about 12-14 oz. of fluid.
Pedal is soft. If pumped two or three times, it firms up, but still feels somewhat soft and fades with continued hard foot pressure.
Do I still have air in the system? If I have a leak that is drawing air in, how do I find the leak? I have gone back and tightened down all connections. Thanks, I would truly appreciate any advice at this point.
John
John
