PatGalvin
Hi Guys
Time to reinstall some new parts (ok, newly cleaned and painted parts).
Brake MC Bracket goes on top. Then we have body sheet metal. The pedal assembly hangs beneath the body, in the drivers compartment. So, how do I bolt this together? Do I run bolts down through the bracket and sheet metal and then through pedal assembly, installing nuts under the pedal assembly? Or do bolts start at pedal assembly and run upward, with nuts on the MC bracket. See attached photo of my bracket. After this is installed, I can hang my MC's on the bracket, attach pedals to MC forks, and then start my hydraulic plumbing. Anything wrong with this sequence?
Completed photos to follow.
Thanks
Pat
Thanks
Pat
