weak brake pedal
saabmp3
So I got my A/H running again last night, almost like a 2nd "first drive" I noticed a couple of disconcerning things that seemed to have fixed themselves this morning.
However, my brake pedal is weak; almost non existant. The first 2 or 3 inches of travel is like pushing on air. Then I get a soft pedal for maybe 1/2 inch (and I can feel the brakes being applied), then it's semi decent for the remaineder of the travel.
This really isn't acceptable to me, I'd like to have nice firm brakes. What can I do to fix this? Where should I start diagnoising this problem?
Ben
jlaird
Bleed em, starting at the rear. Get the air out.
ChrisS
Make sure you adjust the rear brakes properly since they set the pedal. Adjust they until they lock the drim, then back off until the drum rotates freely. Once you do this bleed them RR, LR, RF, LF.
saabmp3
saabmp3
I did make sure to properly set the rear drums when putting the differential back together. I'll try to bleed them tonight. All of these "easy 2 person" jobs become "impossible mano" jobs it seems like.
Ben
kcbugeye1275
Ben, I haven't followed your project, but I had a couple thoughts. When bleeding, make sure all your slave cyl. are good, any fluid near them and they could be your prob. Also front brake lines(the flexible ones) are a potenial problem, if they are old they are a good place to put some money. Good luck and let us know how you got along.
dklawson
Now that you've bled the system and used the pedal to seat the shoes... re-check the rear brake adjustments even though you set them before. It's amazing how much additional pedal travel you can get on LBCs when the drum brakes aren't adjusted properly. Once you've reset the shoes, rebleed the system.
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
P Honda weak brakes Other Cars 10
M Leaky Fuel Pump and Weak Performance Spridgets 14
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
C TR2/3/3A Weak headlight Triumph 7
J Weak spark I think?........ Triumph 49
P Coils and weak spark? Spridgets 1
C TR6 TR6 Advice please: weak spark? Triumph 7
vping Not for the weak. Pics of a Magnette MG 15
P I bought a Singer in a weak moment and ........... Other British Cars 17
vping Need help! Weak spark. MG 20
John_Mc Hard braking goes weak Triumph 5
George Zeck Weak Headlights ??? Spridgets 13
J Rough Idle-Colortune-weak spark? MG 9
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
