Brake light, do you have to remove pedal box?
Thor
My brake light switch just bit the dust and I have been trying to back it out without removing the bolts of the pedal box if at all possible but I can get it out about 2/3rd of the way and then it hits the inner well.
Is there anyway to remove this without undoing the entire pedal box?
Re: Brake light, do you have to remove pedal box?
Nope.
sorry
mark
spritenut
It is possible, but it takes a bit of finesse and a hammer.
A slight dimple with a hammer and the switch will unscrew.
This is also a good idea before under bonnet body work and paint so when the switch fails the next time, it just unscrews.
And you can bend back the tabs on the original switch, clean the contacts and redimple the tabs. I have done it many times with success.
G Brake Light Switch Failure Austin Healey 24
6 E-Type brake light pressure switch location Jaguar 5
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
B Brake light weirdness Dodge Ram Other Cars 5
D TR2/3/3A Brake light switch. Triumph 22
Boink Brake Light Switch... Spridgets 4
RAC68 Third *[3rd] Brake Light Austin Healey 11
K TR2/3/3A 3rd brake light question Triumph 3
L TR2/3/3A Brake light switch location Triumph 9
edkap2002 TR6 stop light [brake light] swith Triumph 9
T Adding a third brake-light Spridgets 5
D extra stop/brake light Austin Healey 33
T 3rd brake light again! Austin Healey 29
T TR2/3/3A 3rd. brake light set up Triumph 12
Jim_Gruber Brake Light - Getting them working Spridgets 8
M TR2/3/3A Brake Light Switch Triumph 24
M_Pied_Lourd TR2/3/3A Brake Light Problem Triumph 9
maxwedge5281 third brake light ideas Austin Healey 34
Gerry M TR6 Brake warning light & oil pressure light stay on Triumph 2
M Brake Light Switch Austin Healey 14
7 brake warning light coming on Other Cars 5
Gerry M TR6 Brake Warning Light Stays On Triumph 3
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
wkilleffer MGB MGB brake light switches lately MG 1
wkilleffer MGB brake light switches of late Restoration & Tools 3
Crankshaft TR2/3/3A Brake light wiring? Triumph 6
I TR6 Brake light on -reasons? Triumph 6
M TR2/3/3A Single brake light modifcation Triumph 2
D TR6 Brake light Triumph 3
N Brake light switch??? Spridgets 9
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
T 3rd brake light or LED's Austin Healey 28
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
mgedit TR2/3/3A Brake Light Switch 56 TR3 Triumph 3
J MGB Question on the brake warning light for 78 MGB MG 6
T TR2/3/3A What is thread size on TR3 brake light switch? Triumph 5
P Brake light switch Austin Healey 12
Gliderman8 Faded brake light lens Restoration & Tools 17
T TR6 TR 6 Brake light on Dash Triumph 4
D Spitfire MKII Spitfire brake light pblms Triumph 3
R more reliable brake light switch!?! Spridgets 13
AUSMHLY Stealth third brake light Austin Healey 26
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
tomshobby new brake light switch Spridgets 10
waltesefalcon Spitfire Spitfire brake light Triumph 3
K TR2/3/3A Generic TR3 Brake Light Switch? Triumph 3
