A friends MGB has the Brake light on all the time. This is after the engine was removed for rebuilding. The light stays on and I think it is the connection that is bad. For those of you that that have this switch, how often does the switch itself go bad vs a connection problem itself? The wires and rubber are very old and brittle, so I suspect the connection.
So, is the switch just testing for fluid in the resevoir? If so, will an ohm meter show that the two leads are connected as long as the fluid is in the reservoir?
Jerry
Jerry
