BillD
Member
Now that I replaced the left front bearings, I checked the right side and found the castle nut was torqued correctly with no noise or wobble from the bearings. However, I'm getting some noise from the brake shoe springs rubbing against the hub. This happens because the shoes are floating outward presumably because of the spring tension. If I push them back, there is no noise. Everything appears to be functioning properly. What's going on and what's the fix?
Thanks again,
BILL D
Thanks again,
BILL D
