59 Bug Eye total rebuild of serious basket case. Will not be totally original. Totally striped, setting in harbor freight engine stand rotisery, floor replacement in process. Gathering major parts. Will be going w/ disc brakes at least on front, probably wire wheels, better stereo, sound deadening material and carpet. Have 948 in very definitely 1st over rebuild condition. Almost for sure will be going w/ 5 speed conversion.
Question: Compare/contrast functional, cost, and performance differences between 948, 1098, and 1275. Fuel economy not the question. Will do all work myself except machine shop expense. I have access to affordable 1098 core (condition unk). Will gladly wait for a 1275 core for overhaul if actually better than 1098. Is the extra 177cc really worth it? Is it actually the same block, just bored more, or stroked longer? Is there a significant performance/longevity factor?
I know this is a big question and calls for opinion on taste (for which there no accounting). Looking for facts on standard performance, as well as mild enhancements, such as mild cam, slightly increased compression, Webber, enhanced exhaust.
I guess the question is: If you had a 59 Bug Eye and wanted to build a daily driver with a little zip, what would you put in it?
