Bug-Eye Bonnet Mounting Bolt Lengths?
twas_brillig
The hinges each have 4 bolts and the manual advises that the inner bolts are longer. Anyone know what the lengths should be for the 'inner' and the 'outer' bolts? Mine are a wee bid of a hodge podge....
Thanks,
Doug
Whitephrog
According to the Service Parts List all eight are 1/4" x 5/8" with a flat washer and a spring washer
kcbugeye1275
All that matters is that they aren't so long that they get into your bonnets sheet metal. Also, when you install, you might want to install spacers so the bonnet lines up with the cowl. A trick, once the bonnet is aligned with even spacing is to drill a small hole through each hinge and the plate it mounts to so when you next take it off, you can simply loosely install the bolts, use your alignment pin in the hole and tighten the bolts and your bonnet is where it was previously.Seems my bolts were 1" x 28 x 1/4".
Joe Schlosser Bug Eye Bonnet Removal Spridgets 1
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
T Bug Eye Heater Switch Help Spridgets 2
equiprx BUG EYE SPRITE, One of a kind print, Signed by the photographer Austin Healey Classifieds 0
I Bug eye front disc brake conversion. Spridgets 5
Joe Schlosser Bug Eye fuel gage sending unit Spridgets 15
F Bug eye interior Austin Healey 2
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
T Will Mini Spin on Adaptor work on Bug Eye? Spridgets 10
Jer Seen a nice "survivor" Bug Eye on the weekend Spridgets 5
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
T sound for a bug-eye??? Spridgets 2
T Lubricating the steering rack on a Bug-Eye Spridgets 12
T Weight of a Bug-Eye bodytub: approx 220 pounds Spridgets 10
donbmw For the Bug Eye fans Spridgets 4
donbmw For the Bug Eye fans Austin Healey 1
BillD Bug Eye front drum brake question Spridgets 12
rkep01 1959 AUSTIN HEALEY "BUG EYE" SPRITE / AUTOCROSSER Spridgets 6
N Bug Eye Hard Top query?? Spridgets 6
Keoke Restired Bug Eye for sale Spridgets 0
B bug eye hard top for sale Spridgets 3
M Bug Eye Door Seals Spridgets 8
jeff1977 Bug eye, id help please Spridgets 21
T Bug-Eye Wheels and Tyres Spridgets 10
T Bug-Eye rebuild & upgrades - advice requested Spridgets 2
J New to forum/new to bug eye/new to vintage racing Spridgets 5
Jer you never know... I just bought a Bug Eye ! Spridgets 21
M Pocket project completed on Bug Eye Spridgets 5
M New carpet set install on Bug Eye Spridgets 15
M Ignition conversion on 58 Bug Eye back to original Spridgets 2
M New Bug Eye Owner Spridgets 10
B 59 Bug Eye Options Spridgets 9
sim Bug eye sprits How may are left Spridgets 15
C A garage find Bug-eye Spridgets 19
GB1 Interesting Little Bug Eye Spridgets 1
dosedtoaster taking delivery - 61 bug eye Spridgets 29
tony barnhill Weird Little bug eye Spridgets 8
K Austin Healey 1958 Bug-eye colors Austin Healey 1
pbraun Bug i nearing final completion Spridgets 11
pbraun Closing in on finishing the Bug I Spridgets 12
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix...Now with Video! Triumph 43
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix... Triumph 15
Mickey Richaud That's Not a Bug; THIS is a Bug! Other Cars 2
Trevor Jessie The Ugly Bug just got a little uglier Spridgets 20
jackq 63 Bug Other Cars 13
MadRiver Pre-War I've caught the pre-war bug MG 29
Trevor Jessie Washed the Ugly Bug Spridgets 21
jackq 70 Bug Other Cars 8
I bug swivel axle help please Spridgets 5
