machine gun brake pedal
eschneider
I was driving my niece's 95(-ish) Lexus this weekend and experienced a rather disconcerting issue with the brakes. They felt fine until we slowed to an almost-stop, when the pedal vibrated/pulsed rapidly and made an audible rattling noise. Kind of like a machine gun. It only did this when almost to a stop, regardless of pressure (no difference between slow stop / panic stop). It's not a cv joint noise.
In 15 years of working on cars, I've never felt anything like this before, but my gut is that it has something to do with anti-lock brakes. Anyone else seen / experienced this?
LarryK
Check the antilock brake sensors. Seems the system thinks the wheels are slipping and you are on full brake lock. Might bleed the system heavily to get the dirt and moisture out. Probably never been bled in 8 years.
Platinum
:iagree:
Sensors are sending a false signal for some reason.
Steve
Platinum
What Doc said.... Unless they we reacting to an actual issue with the road surface? Stop lights for instance tend to get diesel spilled when trucks brake hard and fuel sloshes around. That stuff is as slick as gorilla-snot. Try the car on a different section of road that you know to be dry, if the issue reappears then there's a problem, if not it was the road surface at that location.
P Fuel pump sounds like a machine gun MG 6
C Machine shops Pittsburgh Pa area inquiry Other British Cars 1
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
R Machine Shop St. Louis or Nashville Austin Healey 1
T TR2/3/3A Machine Shop Recommendations Needed Los Angeles/San Diego Area Triumph 0
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
M Machine Shop in Pacific Northwest Spridgets 7
P Fuel Float to tank bolts [machine screw] size?????? Spridgets 1
S T-Series Auto machine shop TD engine MG 20
M Is it a Triumph or a Singer [sewing machine]? Triumph 14
M Portlan Oregon Machine Shops Austin Healey 4
K SU Newppindles and bushes done by a machine shop? Triumph 1
rikiwho123 a good machine shop in N.J.? Triumph 1
J Machine shop in NorthernCal needed Triumph 6
Stewart Machine gunning on acceleration, loss of spark MG 8
jvandyke ghost in the machine/ gearbox and horn? Spridgets 6
TR6oldtimer Need a machine shop in N. Calif to bore for cam Triumph 5
healeynut Pozidrive machine screw source? UNF Austin Healey 3
JodyFKerr Machine shop recommendations [Phoenix, AZ ] ? Restoration & Tools 3
healeynut Monster Machine Other British Cars 6
ronzet Got a call from the Machine Shop MG 14
Geo Hahn My Machine Shop is Closed Triumph 9
davidk Need a machine shop near Northeast Texas Triumph 7
Brosky Cylinder head machine, valve job & CC Triumph 10
eejay56 Bad news from the machine shop Triumph 12
2wrench Picking up engine from machine shop tommorrow Triumph 4
Brosky Block to machine shop yesterday Triumph 8
PeterK Machine shops Triumph 12
John_Mc Mystery Machine pics Triumph 0
DrEntropy Jumped into the Wayback Machine... Lotus 5
G TR6 Does anyone have a machine shop and a TR6? Triumph 15
Bruce_B 1275 Engine Returned from Machine Shop Spridgets 12
L Machine Shop in Santa Barbara, CA area? Austin Healey 0
ChrisS DE machine shop / engine builder Racing 2
D Machine Shop Needed British Motor Corp 6
max71 Looking for a top machine shop in the L.A. area MG 1
Morris Hello machine shop! Spridgets 1
Morris Before I go to the machine shop Spridgets 2
Alan_Myers Need machine shop recommendations - SF Bay area Triumph 0
jlaird Stoped by the machine shop Spridgets 11
T distributor machine Restoration & Tools 3
G Got screwed by a local machine shop Triumph 14
Paul Slice good machine shop around Nashville TN Triumph 0
G Recomendations for Machine shop In Boston area Other British Cars 1
G Looking for good machine shop in Boston area Triumph 0
L Machine shop Santa visit!!! MG 2
Bret BMW - the Ultimate Driving Machine! Other Cars 11
M Michigan machine shops MG 1
aeronca65t WayBack Time-Machine Other Cars 8
S Machine Shop Recommendation Austin Healey 5
