Cylinder head machine, valve job & CC
Brosky
I picked up the block today, plus a card with 100 pictures of the engine rebuilding in progress. It should be running next week.
Some of the head work below:
R
RonMacPherson
Tell us about the valve stem seals. please
Did they machine the guides, or find seals that fit without machining. What seals are they?
Brosky
Brosky
Ron,
The guides were machined and these are NOT Teflon seals. Bob won't use them anymore. Remember TR6 Bill noting that his were bad? Bob said that he sees them fail constantly.
Bob uses these on the racing engines that he builds and they are made for all standard size valves, but custom sizes are readily available. I'll have to find out what material they are. It looks like a spring on there, around the blue seal.
AltaKnight
Paul....
I've got my new BPNW camshaft, new lifters (with the oil drain hole) and shorter pushrods so I'm set to do my engine shortly.
I plan to machine the head to raise compression also; how much did you have taken off yours and what does that push the CR to?
Brosky
Brosky
Graham,
If you follow this chart, you can be right on the money, but the key is allowing for zero deck height, which I have because of all of the work to the block.
You can measure your piston top travel and you will probably be very close, in stock form. I had 0.007" removed from the block and that's got the pistons about 0.0005" above the deck.
My head is machined at the 3.421" mark, which puts me right in between the 9.41 and 9.67, probably at 9.55.
I give you this chart as a reference because you don't know what's ever been taken off of the head before you got it, so it will get you where you need to be.
Which cam did you get? I got the new TH5, which Greg highly recommended based on what I was doing and my driving habits.
https://www.goodparts.com/tech_docs/TR6_Compression_Ratio.html
AltaKnight
Thanks for the info Paul....
I got the TH5 also, though BPNW reccomended only 80 thou removal from the head.
Just have to find a good machine shop now.
The yellow pages lists about 35 in my city.
Just curious, but at what amount of machining does valve/piston contact occur; or is there lots of room?
2wrench
Paul: Will you measure your head top down to bottom?
I'm curious to know how it compares to mine.
Trick6
2wrench:
The amount of machining cut of the head is a good reference but the only way to really tell the compression ratio is to cc the combustion chamber. One of Paul's pictures shows the procedure. It is the last picture of his first post. The head is positioned with the head surface leveled and up and with a clear plastic plate sealing the No. 1 combustion chamber. Notice the spark plug and valves in place to seal the chamber. A liquid is poured through a hole in the plastic and measured as it fills the combustion chamber. The amount of liquid used to fill it, measured in cc's, is the the size of your combustion chamber. My combustion chambers measure 44 cc's which puts me at about 9.98 combustion ratio. There is an equation used to figure that but you must know the deck height, the head gasket thickness (compressed), and the bore and stroke of the motor. You plug those variables into the equation and out comes the combustion ratio. WALA.
The thing I like about the photos is how clean the shop is. There are no shavings on the machines, no clutter on the bench and the floor is clean. Boy, that tells it all.
Platinum
Cleanliness=professionalism. That is one of the FIRST things I look for when going into a shop. ANY shop.
Brosky
Brosky
There is a vacuum system attached to each machine that evacuates chips/powder from the landing areas after cutting. As the Doc says, excess chips cause issues and being a true professional shop, these are not permitted to affect any of his work.
When you build the kind of racing engines that he does, there is no room for error.
I believe that my chambers are matched at 45.5cc's across the board.
I'm having a bit of a problem understanding the .080" removal recommendation from BPNW. Did you speak to Greg about that? I told him that my head would ultimately end up with about .120" removed and he said it would be no problem. How else could I get to 9.5 to 1 without doing that and that was what I gave him for my desired CR when we discussed the best cam for the car to get it as close to 150HP as possible, yet street drivable.
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR2/3/3A Cylinder head threaded plub Triumph 6
R BJ8 Cylinder Head Gasket Austin Healey 38
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B General Tech Cylinder head costs MG 7
J For Sale TR 2, TR 3 TR 4 cylinder head Triumph Classifieds 6
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
K TR2/3/3A Cylinder head valve springs? Triumph 3
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
BOBBYR Cylinder head for sale on ebay Austin Healey 2
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
S TR2/3/3A Cylinder head stud methodology Triumph 11
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
B BN2 Cylinder Head Stud Thead Size/Replacement Austin Healey 0
