Low Brake Pedal
RDKeysor
Bronze
I recently bled the brakes on my '60 BN7 and came up with pretty dark fluid of unknown vintage. Forum members suggested the coloring was likely from rubber deterioration and the master cylinder (MC) likely the culprit. Subsequently, I put a rebuild kit in the MC and pretty thoroughly flushed out the system. I again bled the brakes conventionally, securing a good pedal, but experienced variations in pedal height. Forum members urged me to get a new MC. I installed a new MC, again flushing the system (including removing and cleaning the reservoir), and went around the system three times to insure all air was removed. By the second bleed we obtained a good, firm but low pedal. Lower, I think than I had at the beginning. My rear drums are adjusted to the recommended tension. I am now using NAPA Dot 4, which is the fluid used by our pretty experienced club members.
There are no leaks in the system, as the car has been on jack stands with the wheels off during the repeated bleeds.
I might add that the new MC appears identical to the original unit. Interestingly, or puzzlingly, the interior and fittings in the original MC looked perfectly OK. Subsequent to installing the rebuild kit, I removed and examining the components. Nothing appeared amiss. Nonetheless I then went to a new MC, as described earlier. So why do I have a low, firm pedal? I haven't measured the movement, but it must exceed 2" of travel before going firm. Unlike the situation when there is air in the lines, pumping does not alter the pedal position.
R
RDKeysor
Bronze
Unfortunately, no and no. I assume the bore is the same, making that estimate because the same supplier sold me a rebuild kit that fit the original MC. I do know that there was a difference in MC bore diameter between later servo-equipped and non servo cars. I did the brake hose line change with my Jaguar, so I may have to give that a try. I think that did help stop a condition where the brakes would drag after pulling up to a traffic light. I bought a laser temperature instrument when I was combatting that condition, thinking that just one caliper was dragging. That didn't prove fruitful. Thanks.
Frameman
It might be as simple as the viscosity of the brake fluid, it might be too light. Until a few years I was under the impression that hydraulic fluids are not compressible but it turns out that they are. This was discussed on an earlier thread on the forum. The problem was resolved by changing the brake fluid to one with a higher viscosity. To find out where you can get this in your area please check with Dow chemical. They also recommended not using silicone brake fluid because silicone attracts air in the system. This is important to remember because the Healey brake system is a vented system not a closed one.
roscoe
I suppose there are many different experiences out there but when I did my rebuild, including all 4 slave cylinders and master cylinder I chose silicone brake fluid. I had a few minor seeps for a short period of time but it has been absolutely trouble free and not leaked a drop in the last 5 years. I did put in stainless brake flex lines and have since put front disc brakes on. I'm a fan of silicone if put in an all refurbished system.
bdcvg
Silicone fluid does not absorb water, which is a good thing except water is eventually encountered in brake systems. Conventional fluid turns dark with moisture, time to change. Silicone fluid floats leaving the moisture to collect in low spots in the lines. If Your car sits for long periods the water starts eating the insides of your lines.
why
Um, I am not sure about adjusting drums according to a spring tension. I have always just turned the adjuster wheel on each side until you just feel the shoe against the drum. for many different cars and years of manufacture. If you do that and find the pedal now higher, then just back off adjuster one "notch", pedal should be about the same and you are ready to go. If not then problem is elsewhere
steveg
....but it must exceed 2" of travel before going firm. Unlike the situation when there is air in the lines, pumping does not alter the pedal position.
Pedal travel will be greater than MC piston stroke travel. According the Pegasus catalog, the stroke of Girling MCs is 1.375". Have you pulled the boot back and observed how far down the MC piston goes before coming up solid? If the piston goes down 1.375" you are hitting bottom.
Are you using the stock pushrod or do you have an adjustable clevis? Do you have a booster in the system?
R
RDKeysor
Bronze
I am using the stock push rod that came with the new MC. I had it side by side with the unit I removed, and they appeared identical. There is no booster on this car; series one cars didn't come with them as an option. I have a servo kit from VictoriaBritish--I have already installed the mounting plate--but won't install the unit until, and if, I get the brakes working properly. You have previously suggested not installing the servo as it adds additional complexity to the brake system, that thought registers with me. Here's another wrinkle. The May issue of Healey Marque includes an article by Mike McPhail regards brake bleeding. Though I can't find where he mentions rear brake shoe adjustment earlier in the article, in the penultimate paragraph he says this: "Since you have the rear brakes adjusted up tight, the pedal should have very little play. If satisfied, adjust the rear brake drums (shoes) so they just barely drag." My rear brakes are set in the normal position, one click off dragging. Mike McPhail's reference to rear brake adjustment is something I've heard before, and I think I will give that a try when I get my water pump installation completed. I will also check the piston movement on the original MC, since I think it is identical to the new one. I'm not dismissing the idea that ultimate piston travel is the key brake pedal travel.
af3683 Low Brake Fluid Triumph 14
hondo402000 TR6 figured out my low brake peddle problem TR6 Triumph 1
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
T TR6 Low Oil Pressure Light Triumph 3
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
JFS Wedge Low Coolant Light Triumph 7
O Low manifold pressure! Jaguar 8
warwick-steve How low is too low? [spring question] Austin Healey 19
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
S Low entry cost into AH ownership? Austin Healey 18
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
charleyf TR6 low speed stall Triumph 51
CJD General TR New Low for Ebay Triumph 21
Jim_Gruber BE Hi Low Beam Footswitch and Relays Spridgets 6
doc50 TR2/3/3A Speedo reads way too low Triumph 13
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
F TR6 Starter Relay = Low Engine Power Question Triumph 13
M TR2/3/3A Low charge with Alternator Triumph 5
B No Low Beams Austin Healey 1
CJD TR2/3/3A Low Port Head Cracks Triumph 36
aeronca65t Post-War Other super low mileage Herald Triumph 2
R low/high temp engine running question Spridgets 23
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
AH67 ‎62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
B TR6 Low mile tr6 Triumph 12
D Carburetor Backfire on acceleration at low speed Austin Healey 18
V Low Oil Pressure Triumph 4
H low oil pressure Austin Healey 15
