low/high temp engine running question
recordsj
With thiscooler weather my 1500 MG midget engine has been running cool. It has a180deg F thermostat. When cruising down the highway (45-55 mph), theengine will run @ around 140 to 160F. In town it will get up to 170-180F. I have already swapped out with new thermostat and engine still does samething. The radiator has a thermostaticcontrolled electric fan set to turn on @ 185F. Shouldn't the thermostat with an opening temp @ 180F keep engine at thatmin temp?
Any thoughts?
I have done apressure test of the system and the cap and it holds 15psi.
During thesummer I would be having temps running @ 200-210F (especially going uphill @45-55 mph). Typically the engine would be running @ 180-190F.
Any thoughts?
Temps have beenconfirmed with a laser thermostat.
I have madesure that the system is bled to get air out also.
SaxMan
Stuck thermostat? I'm having a similar issue with my '69 Sprite. The temperature gauge never gets up into the "normal" range, even in the middle of summer. I just swapped out the thermostat last night, but probably won't get a chance to test drive it until the weekend. Of course, I may just have a bad temperature sensor / sender as well.
R
recordsj
Tested the old thermostat and the new one in a pot of water brought up to boiling, both open up 180 F. Confirmed gauge reading with laser thermostat.
R
recordsj
With or without a thermostat, cool air absorbs more heat thru the radiator than warm air. Don't worry about this. Bob
True the radiator will expell heat better in cool air. With that said the thermostat should close more to restrict flow since water is colder. The issue is that with the engine not getting up to proper operating temp, it won't run as efficient and the engine oil won't burn off water and other contaminants.
bobhustead
Combustion chamber temps are virtually unaffected by the described variation in coolant temp. Thermostat opening can be regarded as on/off, not gradual. You might have a tstat that is opening early, but once again don't worry about this. Bob
aeronca65t
The 1500 horizontal flow radiator is really efficient at cooling, so this is not that surprising. Especially with a 185F thermostat. Many of these cars came with a 193F thermostat as standard. My 1275 race car is running a 1500 radiator and I also have issues with overcooling (at times). Overall, this is a "good" problem and is easier to deal with than the overheating problems some Spridget owners deal with when using the older-style vertical flow radiator (which can be marginal in some warmer climates). If you feel you'd like to bump up the temperature in the cooling system, simply block off part of the radiator. You can experiment with cardboard pieces first and once you've got a size and shape figured out, you may wish to fabricate a nicer-looking aluminum shield. But don't block off too much.....it's always safer to run a bit cooler rather than too hot.
R
recordsj
If the cross flow radiator is so effcient, why in the summer would I run temps around 210F (w/ 180F thermostat)? Or is 210 not really that hot to be considered overheating (w/ 50% mix of water and antifreeze)? This seems to be a big temp fluctuation.
aeronca65t
OK, that's wierd. 210F is hot for a Spridget. All I can think of is that your lower hose is collapsing in the hotter temps (the lower hose is under suction). Sometimes, then they get old and soft, they collapse when running. The cooler temps may be keeping the lower hose ridgid enough to flow properly. Otherwise, it could be a funky thermostat, a really old fanbelt or waterpump with corroded impeller.
bug_sixty
In these discussions... the correct fan belt isn't discussed... as in slipping and not getting the pump the 100% efficient rotation...
R
recordsj
Replaced thermostat, issue still there.
New pump about two years ago.
New belt about three years ago from Moss.
No noticable noise from belt.
New hoses two years ago.
I guess I wouldn't discount hose collapsing (will try to see what is happening next summer when I would see hotter engine temps see with current cooler temps not seeing 210F).
G
Have we talked about timing yet? Wonder if you may be running lean too.
R
recordsj
I should add that the engine is 9:1 copression using premium gas, which maybe adding to the heat load.
SaxMan
Have you checked your air/fuel mixture on the carbs? A leaner mix will tend to run hotter, and a richer mix will run cooler (something I picked up from the guys who work on radial aircraft engines). I found that holds true with my Sprite. Now that the carbs are leaned out, I'm seeing warmer temps on my gauge, but still on the low side of the N.
R
recordsj
With the cooler weather engine is running cold, 140-160. In the summer engine was running hot 180-210. Don't think it is an issue of running rich or lean.
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
eschneider Twin cam crankcase pressure low, VC pressure high Lotus 21
wkilleffer Adding relays to the low and high-beam circuits MG 10
zimmy pricing my car ....too high, too low? Spridgets 0
S BJ8 horns, high & low note directions Austin Healey 12
M 90 XJS V-12 High Fuel Consumption & Low Power Jaguar 60
C Front Carb Fuel Level Too High, Rear Too Low Triumph 8
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
T TR6 Low Oil Pressure Light Triumph 3
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
JFS Wedge Low Coolant Light Triumph 7
O Low manifold pressure! Jaguar 8
warwick-steve How low is too low? [spring question] Austin Healey 19
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
S Low entry cost into AH ownership? Austin Healey 18
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
charleyf TR6 low speed stall Triumph 51
CJD General TR New Low for Ebay Triumph 21
Jim_Gruber BE Hi Low Beam Footswitch and Relays Spridgets 6
doc50 TR2/3/3A Speedo reads way too low Triumph 13
R Low Brake Pedal Austin Healey 9
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
F TR6 Starter Relay = Low Engine Power Question Triumph 13
M TR2/3/3A Low charge with Alternator Triumph 5
B No Low Beams Austin Healey 1
CJD TR2/3/3A Low Port Head Cracks Triumph 36
aeronca65t Post-War Other super low mileage Herald Triumph 2
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
AH67 ‎62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
