TR2/3/3A TR3 Low Port vs High Port Head
carpecursusII
Ok, on a basket case I purchased I have a TS 433xx engine on a TS 428xx car. I just noticed today that I have a low port cylinder head with a high port intake. How much trouble am I in here, what are the consequences of not switching heads. I am trying to build this car to concourse quality.
TR3driver
Great Pumpkin - R.I.P
Yup, intake manifolds won't match up. The head studs are different, too.
And the difference is pretty obvious, so the odds of a judge spotting the discrepancy are high. I forget the change point offhand (some time during 1956), but you are way beyond it.
Adrio
I was only 18 when I got my TR3 but it turns out to have had a low port head and I drove it for years and had the head rebuild before I realized it was the wrong ported head. The gaskets did not fit and that was how I found out. I think the manifold was just ground down to make it work. But my advice is to get the proper head. I will do that once I get some time and find a head.
TR3driver
I suspect that once word gets out, there are at least a few "originality" types who would be happy to get hold of a good low-port head!
If so, I've got a "Le Mans" style head available, correct for TS9350E through about TS12606E. Needs to be rebuilt, the valve guides are badly worn, but was "running when removed". I forget the engine number it came off of, but I can check if it makes a difference. The short block is in the shed with a high port head on it.
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
PatGalvin TR2/3/3A TR3 Leaf Spring Rebuild - low friction tape? Triumph 9
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
