Jim_Gruber
Doing some electrical wiring planning for Bugsy II. I know I want to use relays on Hi/Low Beams but rather than lead wiring back through relays mounted on inside of firewall behind dash on PS, thinking about putting 2 Relays in top of DS footwell top corner. I seem to recall someone doing just that. Anyone got any suggestions?
Also wiring harness was out of car when purchased so I have no idea on wiring routing. I will be using a front tilt bonnet so I will need to run wiring for turn signals as well as power for an electric fan to the front as well. Looking for ideas on:
1) Quick Disconnect - for wiring running to front. I used a 6 way trailer harness plug before but not real elegant.
2) Suggested location for headlight wiring route if going front tilt. Do I run from Footswitch up and under dash and down the PS with bundle of wires that need to run to front of car do I have one bundle going up there or run all wiring down the DS.
3) open to suggestions at this point. Just trying to plan so new harness can be built by British Wiring.
4) Relays planned for Headlights(2), electric fan, fuel pump any other suggestions
5) suggestions on small fuse/relay panel to terminate wiring mounted on firewall on inside that can be accessible to replace fuses or relays as needed.
6) will add aux power for accessories and a circuit for some sort of music source . Have not decided on tgat but likely something hidden, Bluetooth, wireless speakers
If you were to rewire what would you change. Or add to a wish list. Thanks.
