The Roadster Factory Recovery Fund - Friends, as you may have heard, The Roadster Factory, a respected British Car Parts business in PA, suffered a total loss in a fire on Christmas Day. Read about it, discuss or ask questions >> HERE. The Triumph Register of America is sponsoring a fund raiser to help TRF get back on their feet. If you can help, vist >> their GoFundMe page.
Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Randy,
I replaced my original brake light switch a few years ago with a switch from Moss #54033360. The new switch is made by Intermotor (their #51630). It failed after two seasons. Replaced it last October with the same type switch. It leaked. Replaced it again.
I guess what I am saying here, is that the switch is most likely your problem. If you order a new one, you might just save some postage and order two.
Sorry to hear Randy has that problem. It's because he hangs out with me.
Some nice guy at a stop light told me my break light does not come on. I pushed harder and then he said it did.
I ordered a new break light switch, installed and thought that fixed it. Read, thought that fixed it.
How does Randy know he has this problem. I was driving behind him and told him so. How do I know I still have the problem, he drove behind me and said you too.
Being positive about Healeys...Oh boy, I get to work on it again. Cheers, Roger
When installing a new brake light switch, I have tried to put a little brake fluid in the opening of the switch before screwing it into its holder in order to deminish the chance of air being trapped inside the switch. My thinking is that even a little air trapped inside the switch would require more pressure to activate the switch, and that air may not ever work its way out of the switch. Don't know if that makes sense, just the way I've done it.
I use to have the same problem with my '62 BT7. Some folks think silicone brake fluid is part of the problem. For awhile, I could get dirt cheap VW switches from JC Whitney that workked but they must have wised up and upped the price.
I finally installed a MG brake pedal actuated switch maybe 2 or 3 years ago. No problems since.
Re: Brake Lights Work Only With Heavy Pedal Pressu
I had the same problem. I skipped trying another original switch and bought and installed one of these: https://www.watsons-streetworks.com/get_off_juice.html
The hard part was making and installing a custom metal bracket above the brake pedal to hold the switch. I ran the wires out the same hole as the dimmer switch wires and then connected to the connectors going to the old brake switch. That way it is easy to unplug the new switch and plug back in the old or a replacement old type switch. This switch has been working flawlessly since I installed it so I won't be going back to the old style.
Fantastic solution to my problem guys. I'm going to replace the hydraulic switch with the mechanical Watson's-Steetworks unit. This is a nice and simple, straight forward solution. I love it.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
