Everything was goin good... now no brake lights
cl_miata
well I replaced the brake light switch a few weeks ago, (has a total of like 50 miles usage) and finally got it back together tonight with the new carpet, went to go for a spin, no brake lights, moved the connector to goes from the wiring harness to the brake light wires and all was good,I then proceeded with my drive, came back home, then decided to run to the store with he midget, and once again no brake lights, this time took the rubber off the connectors, discovered they were quite rusty so replaced them all together, and still no brake lights, have tail lights, and everything else though... I'm not enjoying this MG ownership all that much
Yup, you need to clean all the electrical connections and ground wires. (It's an old car). Also, be aware that your replacement switch may have already burned out (Some of them are just that poor). Did you keep the old one to rebuild as we mentioned earlier?
startech47
Apply distributor dielectric grease to the connectors as you reassemble them. This keeps Oxygen away from the mating surfaces and reduces oxidation. The contacting surfaces will push the grease out of the way and allow electrical contact. You just need a thin coat. Don't overdo it.
C
cl_miata
Well all the connections for the brake switch is new, and everything else is working... I jumpered the two posts on the switch together and the brake lights still didnt light up?
Is there power to either post on the switch? (Remember to turn the key on to test)
If there is power, then start checking connections at the brake light and move forward. If there is not power, work from the switch back to the fuse box.
May be simple as the bullet connectors where the main harness ties to the rear.
Morris
I had a similar problem. The solution was to clean, clean, clean, sand and clean the contacts on the fuse box. I also use a relay to switch my brake lights. The design for the brake light switch whether new or Chinese/Indian reproduction is just crappy.
jbowlby
Also don't forget the grounds. One on the firewall and one in the trunk. Just because they may me tight dosent mean they are grounded. Remove scrape to bare metal and re-fasten.
C
cl_miata
Ah, cleaning the fusebox was the key... my tach also started working normally along with my fuel gauge.... I bought that relay for the brake light switch, but lost the instructions so am going to have to find them again
jlaird
Well done.
bgbassplyr "Everything was working when I parked it." Triumph 7
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
steveg Steve Kingsbury has lost everything. Austin Healey 11
Boink Center justification on everything now... FORUM Navigation Questions 3
B Everything runs better with this mod - all models!!! Spridgets 7
PeterK General TR Holden UK sale 15% off everything Triumph 0
Randy Harris Timing is everything - the question is - is this the time? Austin Healey 14
H Don't you love it when everything is working right Austin Healey 1
7 Its driving season and everything works Triumph 5
Frankenhealey Aluminium everything - weight saving? Austin Healey 3
S I've tried just about everything but....... Triumph 7
Tabcon EVERYTHING MUST GO!!! Racing 3
T Getting everything out of the M/C Spridgets 10
jlaird Everything loaded up Spridgets 13
sparkydave Everything's working right! Wow! Spridgets 3
regularman Do you paint everything? Spridgets 2
G When you rebuild your car double check everything Triumph 7
bcliff New Owner, need info, parts, and everything! British Motor Corp 5
jlaird Everything you never wanted to know about bolts Spridgets 0
AngliaGT "I WAS SEVENTH!" Racing 0
mezy Look what I was in yesterday Other Cars 14
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
S TR2/3/3A my OD stopped working after it was working Triumph 25
dougie Use your car as it was meant to be used Austin Healey 15
drooartz General MG Surprisingly enough, I was right! MG 7
JPSmit well that was fun Spridgets 1
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
Gliderman8 General MG The car that never was MG 6
Got_All_4 TR6 This frame was sectioned Triumph 9
S TR2/3/3A and the radiator was leaking. Triumph 7
Jim_Gruber Boy was I ever surprised on Saturday Spridgets 11
K TR2/3/3A It was all going so well....... Triumph 11
tinman58 General TR Well that was close! Triumph 12
T Was Sophia Loren ever photographed with a Healey? Austin Healey 2
Trevor Jessie When was the last time you bled your brakes? Spridgets 4
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
HealeyRick DMH was a Nasty Boy Austin Healey 2
catfood So thats what it was... Other British Cars 0
Zitch TR4/4A Door Weather Strip Channel - Was this added? Triumph 4
tinman58 General TR It was just a loose wire Triumph 15
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
T Was the Bugeye a Mk I from the get-go? Spridgets 9
PC Dang, that was too good to be true... Restoration & Tools 3
Jim_Gruber Bugsy was out for his first real romp today! And it was fun!!!! Spridgets 3
JPSmit Tesla - but that's not what was interesting Other Cars 2
H At least the Bugeye Shirt was at the HPDE this weekend. Spridgets 5
drooartz MGB Today was a good day - the MGB is legal! MG 6
longbridgehealey When did you buy your first LBC, and what was it? Spridgets 46
