Its driving season and everything works
70herald
At least everthing on the Herald was woring well enough to pass the safety inspection and get back on the road :thumbsup:
The old inspection sticker expired in 2008. Then the newly rebuilt head started causing problems and I discovered an old, repaired crack in the head, so off with the old head and on with a brand new fresh from Mr. Stan Parts never touched casting. Only problem was that it was for a 1500 engine and I have a 1290. Took allot of machining to get the compression ratio right.
So now for the first time since I bought it, the engine seems to be just right, the gear boxs shift properly, the chassis isn't loose and wobbly.. to bad the paint is all falling off. but who cares it is just about perfect driving season here.
Brosky
You just had to say that didn't you????
Seriously, I hope that it all stays running well for you. Was having a different head a good or a bad thing for your engine? I must admit that I don't know much about Heralds.
70herald
A 1500 head on a 1300 block would have resulted in very low compression. I had to have something over 1mm removed to get the compression back up to normal. The only other difference is that it has much larger intake valves than the original head. Doesn't seem to make much of a difference. Of course getting rid of the crack in the head did make a big difference :blush:
tdskip
Well do driving already then! Grin.
Send pictures - and enjoy. I know it has been a lot of work to get to this point.
Brosky
Don, it was raining again this morning. Church picnic was this afternoon and I ate too much, as usual. Time to take a nap.............
anarchy99 Driving season... Spridgets 2
Sherlock It's driving season finally! Spotted 5
Jer 2014 Driving Season... Spridgets 8
drooartz The end of a great driving season MG 0
T Prime driving season in AZ! Triumph 4
T Extended driving season? Triumph 5
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S Spridget Mountain Driving Tour : Mid-Atlantic Spridgets 8
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
T how to have music/radio when driving Spridgets 33
C How to install Stone Guards on driving lights? Austin Healey 7
C Wiring for two front Driving Lights? Austin Healey 22
maxwedge5281 Driving Lights [picture posting opportunity!] Austin Healey 25
H driving dog [gear] for distributor? Austin Healey 17
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
T 100/6 vs 3000 driving experiences Austin Healey 71
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
R Winter Driving Austin Healey 24
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
M Driving/Owning Comparison between TR3 and AH3000 Austin Healey 13
M TR2/3/3A Driving Comparison between TR3 and AH3000 Triumph 40
vette Driving and/or Fog Lamp Bulbs Austin Healey 5
D TR2/3/3A Driving lights / badge bar attachment. Triumph 4
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
steveg Lousy driving light bulbs Austin Healey 0
bugedd Driving to elevation Spridgets 3
Got_All_4 TR2/3/3A Looking for advice in driving a TR3 with overdrive Triumph 6
steveg Healey hot weather driving observations Austin Healey 2
B Distributor driving gear orientation Austin Healey 2
turtle Avengers Assemble! Tony’s Driving a Healey... Austin Healey 1
2 TR2/3/3A Winter driving question Triumph 10
JPSmit Driving on the 401 today Other Cars 5
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
bugedd How is your driving weather? Spridgets 12
KVH TR4/4A I Sure Like Driving My Triumph Triumph 8
K Spitfire '78 cuts out after many miles of driving Triumph 8
D Ticking noise when driving Austin Healey 8
S Driving Lamps - how to tighten? Austin Healey 8
AHS TR2/3/3A Resto [almost] finished - first driving impressions Triumph 16
toysrrus TR2/3/3A Lucas "Driving / Fog" Lens wanted: Triumph 9
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
RickB Installing flip front kit, what's easiest way to secure back of bonnet for driving? Spridgets 40
S Highway Driving Spridgets 22
