Driving Lamps - how to tighten?
SteveHall64Healey
I have two Lucas tripod driving lamps mounted via clamps on the badge bar of my BJ8. Trouble is that they refuse to remain in position. I have tightened the clamps multiple times and am fearful of going too far and breaking the clamps. Has anyone dealt with this successfully before?
thanks
Steve
Bobbydsport
Steve I've never had to deal with driving lights but in similar situations I have put a wrap of rubber tape around what ever bar I was clamping to in order to give the clamp something to bite into.It usually only takes one or two wraps.I'm sure others will have other solutions.
Bobbyd
Keoke
Hi Steve.
I believe that your setup and mine mount different. My NOS Lucas- lamps have threaded stems on them and mount to small plates welded to the bar. No problem in many years using this set up.--FWIW
stevebt7
I had the same problem with my Bosch driving lights. The rubber tape will work but I cured mine with a strip of old inner tube placed between the lamp clamp and the badge bar. Cut to the same size as the clamp, it really can't be seen unless you look closely. If your lights use the clamp/badge bar for the electrical ground, i.e., only one wire from the light, you'll have to connect another wire to the ground terminal in the lamp housing and connect it to one of the bumper bolts or other suitable location.
S
SteveHall64Healey
Thanks guys. I tried wrapping electrical tape around the badge bar when I first installed them, but the tape bunched up as I tightened. I will give the inner tube idea a try - sounds promising. When I wired them in, I ran both leads to the lights and grounded within the engine bay, so grounding shouldn't be an issue.
steve
healeyblue
electrical tape is no good, because when it gets hot the adhesive on the tape actually gets very slippery and it is worse. The inner tube idea is the best.
Bobbydsport
Rubber electrical tape has no adhesive,it only sticks to itself. However the idea got the creative juices of the forum going.Good stuff.
Bobbyd
S
SteveHall64Healey
i tried this shortly after you posted it Steve. It has worked perfectly - thanks!
steve
vette Driving/Fog Lamps Austin Healey 3
V Anyone have fog/driving lamps on their Spridget? Spridgets 11
bighealeysource Mounting of Lucas driving lamps on BT7 Austin Healey 3
MadRiver TR5/TR250 Fog/driving lamps on a 4 or 250? Triumph 5
angelfj1 Period Switch for Driving and Fog Lamps Triumph 3
LastDeadLast TR6 Round driving lamps for 72 TR6 Triumph 17
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S Spridget Mountain Driving Tour : Mid-Atlantic Spridgets 8
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
T how to have music/radio when driving Spridgets 33
C How to install Stone Guards on driving lights? Austin Healey 7
C Wiring for two front Driving Lights? Austin Healey 22
maxwedge5281 Driving Lights [picture posting opportunity!] Austin Healey 25
H driving dog [gear] for distributor? Austin Healey 17
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
T 100/6 vs 3000 driving experiences Austin Healey 71
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
R Winter Driving Austin Healey 24
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
M Driving/Owning Comparison between TR3 and AH3000 Austin Healey 13
M TR2/3/3A Driving Comparison between TR3 and AH3000 Triumph 40
vette Driving and/or Fog Lamp Bulbs Austin Healey 5
D TR2/3/3A Driving lights / badge bar attachment. Triumph 4
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
steveg Lousy driving light bulbs Austin Healey 0
bugedd Driving to elevation Spridgets 3
Got_All_4 TR2/3/3A Looking for advice in driving a TR3 with overdrive Triumph 6
steveg Healey hot weather driving observations Austin Healey 2
B Distributor driving gear orientation Austin Healey 2
turtle Avengers Assemble! Tony’s Driving a Healey... Austin Healey 1
2 TR2/3/3A Winter driving question Triumph 10
JPSmit Driving on the 401 today Other Cars 5
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
bugedd How is your driving weather? Spridgets 12
KVH TR4/4A I Sure Like Driving My Triumph Triumph 8
K Spitfire '78 cuts out after many miles of driving Triumph 8
D Ticking noise when driving Austin Healey 8
anarchy99 Driving season... Spridgets 2
Sherlock It's driving season finally! Spotted 5
Jer 2014 Driving Season... Spridgets 8
AHS TR2/3/3A Resto [almost] finished - first driving impressions Triumph 16
toysrrus TR2/3/3A Lucas "Driving / Fog" Lens wanted: Triumph 9
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
