TR2/3/3A A cut down side curtain for Fall driving?
karls59tr
Bronze
My TR3 is quite comfortable for cool late Fall driving when I have the heater on and the tonneau cover up except for the cold wind coming in from the driver's side cutaway door. I know that there is a company that makes an above door panel but has anyone tried to make one out of an old side curtain and have a picture?:cold:
Geo Hahn
Seems like you could make one out of vinyl that just snaps (LTDs) from the dash end, along the door and to the rear capping. You'd have to 'install' it once you're in the car but not a big deal and easier to store than a rigid affair.
Another way to get some air flow protection is with a wing along the top of the door:
Pretty easy to make with some Plexiglass and a heat gun. Used in combination with the standard wind wings it is quite effective.
glemon
Although I don't have any pics, I know my brother got an extra set of old side curtains (years ago when they were still pretty cheap) and did just that, cut them down to provide some shelter from the wind, worked pretty well.
Number_6
Never tried it but might be able to find a cheap set on eBay. Sounds like a good idea. i have a set that don't fit properly. might give it a try modifying them.
TuffTR250
I was talking to a guy this week at VTR and he had a set of vinyl panels like Geo mentioned where it uses Lift-the-Dot connectors and connects at the front on the dash stud, then along the tonneau studs on the door, and then on the rear capping stud. He noted that a long stud is needed on the rear cap location. He did not have them installed but it appeared that they could be installed from outside the car except for the connector on the rear cap. He said they work great in conjunction with the wind wings in cold weather. I did not get the name of the company that made them for him, but I do recall he said the guy that made them has a shop real close to The Roadster Factory shop in Pennsylvania. He said someone in TRF probably could tell you the name and phone number.
They looked fairly easy to make, so making them yourself is an option. And the good part is that they use the Lift-the-Dot connectors which are not expensive. There is a really good fabric store here in Raleigh that sells vinyl intended for exterior use on boats so it is very waterproof. That would work very good for these. It is more expensive than interior vinyl but not a lot more, and it would not take much fabric to make the covers.
Regards,
Bob
I have a set of side curtains a PO had that covered with sheet aluminum that look pretty decent that could be used for your project. PM me if interested
MArv
Geo Hahn
I was talking to a guy this week at VTR and he had a set of vinyl panels... He noted that a long stud is needed on the rear cap location... I did not get the name of the company that made them for him, but I do recall he said the guy that made them has a shop real close to The Roadster Factory shop in Pennsylvania...
Possibly Larry Learn?
BTW - These folks have long LTD pegs: https://www.macsautoparts.com/ford_...ickel-double-stud-on-8-32-machine-thread.html
Rut Cut down windshield Spridgets 22
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
69MGC MGC Cut out the Rust! MG 9
D cut-off switch Austin Healey 20
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
CJD TR2/3/3A Cut away TR3 Triumph 6
Boink Moss Healey Cut-out... I'll ask... Austin Healey 2
Boink Cut-away B series engine... MG 6
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
BobMunch MGB The MGB Cut-away, Heritage Motor Centre Museum MG 11
J Windshield question pt.2: Why not cut the frame? Spridgets 9
Boink Battery cut-off switch options... or??? Spridgets 10
K TR2/3/3A TR3 Cut Off Side Curtain. Triumph 18
D battery cut off switch Austin Healey 29
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
Tinkerman Battery cut-off switch installation Triumph 22
AUSMHLY fuel cut off Austin Healey 23
vping T-Series Adding a battery cut off switch. MG 16
G To cut or not to cut Austin Healey 3
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Ouagabambou Cut, torn steering inner tube [+ photograph] Austin Healey 22
T TR6 What year TR6 cut over to Type-J O/D? Triumph 3
roofman Looks like Dale made the cut! Triumph 13
B T-Series cut off switch in MGB? MG 7
T What year cut-over to the 1500? Spridgets 13
jmwuva05 Fuel pump cut off switch Spridgets 6
R Cut off switch wire Austin Healey 2
jlaird First cut on trophies for Lake of the Ozarks Spridgets 32
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
J TR6 Inertia cut out [off] switch TR6 Triumph 9
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
T What do you guys use to cut floor pan sheet metal? Triumph 7
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
tahoe healey fuel pump cut off switch post Austin Healey 21
T Cut/Splice Spark Plug Wires?? Triumph 13
S Battary cut off switch Austin Healey 1
R6MGS T-Series Late MGB fuel cut off switch MG 5
A dash light cut off switch Austin Healey 9
jlaird Bat, cut off switch Spridgets 7
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
G Fuel cut-off valve MG 5
A Battery cut off switch Austin Healey 15
