T-Series Late MGB fuel cut off switch
R6MGS
So, today I went to retrive the MGB LE from outdoor storage for 6 months....this is the third winter it's been outside, and with my method of preparation it is exactly as I left it. Dropped it off the stands, put in the battery(the TR battery barely fit BTW) turned the key..and BOOM she started, first crank...without even having to turn over many times...I was very impressed! So I get a few block down the street, start smelling some gas(and i did check for leaks before I left)...anyway, pull over and discover that it's coming from the switch that cuts off fuel on impact)located right beside the M/C)....I drove back quickly and with the help of my 5 year old neice(I think it's time she gets one of these)was able to bypass it for now and everything is fine....but I have a few questions about the switch....Where can I get another(not listed in MOSS) and which year did MGB's start having this....I am not sure, but I don't remember seeing one on the 78's(I'll have to look next time I am there).
Platinum
A hateful device designed to cut off fuel in the event of "inverted flight." My suggestion is to bypass it and "press on regardless."
...but I've no relatives to concern meself with, y'see.
R6MGS
R6MGS
Thats the way I am thinkin too....See right now I was able to repair it using a small pipe of copper tube by little neice found...but the smaller diameter is restrictiing fuel, thus making for some hard starting...So I am gunna check around for a replacement switch, if no luck then I'll run a line direct to the fuel filter and remove the switch entirely.
Kimberly
They are prone to leak. Very few of our cars still have them. Just use a new length of hose and bypass it all together. There is another fuel cut-off switch under the dash. When the car rolls over it turns off the power to the fuel pump.
tony barnhill
Great Pumpkin - R.I.P
They're "NLA" - & rightly so...pian in the butt, if you ask me....just bypass it....you can keep it in there for shows and originality if you like.
R6MGS
R6MGS
Think I will..I'll remove it first, clean the area up, then put it back an bypass it.
Joe Reed MGB DIY Late MGB Mud Shield MG 0
wkilleffer MGB brake light switches of late Restoration & Tools 3
B MGB Too late to turn back now. 67 MGB MG 147
1 MGB MGB: early or late? MG 7
7 MGB Late MGB Manifold Modification Question MG 8
glemon MGB Late MGB Wiring Questions MG 11
S MGB Replacing convertable top on late model MGB MG 6
V MGB Replace late intake manifold angled breather with early model straight? MG 1
C What to do with my late father's Healey 100 Austin Healey 5
K TR6 TR6 late rims wanted Triumph 0
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
T TR4/4A Recommendation on top for a late TR4A Triumph 8
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
Alfred E. Neuman Late Healey 3000 Spotted 0
JPSmit Late night Benz [no pics] Other Cars 3
B Wanted Late TR6 Gearbox frame Crossmember Triumph Classifieds 1
M TR2/3/3A Late 57 Production with a Small Mouth Apron Triumph 16
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
L For Sale late tr4a IRS project Triumph Classifieds 0
T TR2/3/3A Early/Late Starter? Triumph 6
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
Marvin Gruber Mounting info needed for late BJ8 license plate holder Austin Healey 9
S Late 1930s Business Coupe Other Cars 1
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
TR3driver TR2/3/3A Late TR3A fuse box mounting Triumph 10
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
B TR4/4A Late TR4A - Anyone know what this is ??? Triumph 10
eschneider Any late-model Mercedes owners willing to review new brake pads/ rotors? Other Cars 4
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
Keoke SEE it is never too late Austin Healey 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
Mickey Richaud Early [late 30's?] 10 Spotted 0
B TR6 Vacuum retard late TR6 Triumph 4
B TR6 Is the "separation tank" in late model TR6's necessary? Triumph 5
G Late model head light circuit Spridgets 3
af3683 TR2/3/3A Late TR3 Starter Triumph 3
B Spitfire How do you replace U Joint on late model Spitfire OD Prop/Drive shaft? Triumph 7
6TTR3A TR2/3/3A Late TR2 Grill surround Triumph 12
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
D Late to early bumper swap Triumph 10
