TR2/3/3A Lucas "Driving / Fog" Lens wanted:
toysrrus
Hi Folks,
I`m looking to buy a "Lucas Fog / Driving Lens" only (Only 1); Working or not, Wired or not. This is for cosmetic use only. I have all the mtg. stuff so; "ITS THE LENS ONLY"!!
I`m not sure which is considered "Fog vs Driving" lens but the one I`m looking for is the "Flat Faced" & not the "Ribbed" one. I think thats considered Fog but ??
I went to post this in the classifieds & Panjo is asking me for all sorts of "PayPal" info that does`nt apply. It was geared to "Selling" as opposed to "Buying"?!?!?!?!?
Looking forward to hearing from someone.
Thanx, Russ
Andrew Mace
The "ribbed" lenses are the fog lamps, and the "clear" are the driving lamps. Which model Lucas lamp are you looking for? There are quite a few: Square 8, 576, 700, Ranger, "New" Ranger, etc.! Regardless, expect to pay nowadays for excellent used or NOS lamps.
HerronScott
Russ,
These ribbed ones were called Fograngers as Andy indicated so I'm guessing what you want is a driving lamp lens.
Scott
toysrrus
toysrrus
Hi Scott,
Yes; Its the "Driving Lens" I`m looking for. I`m attaching a pic of one I already have as I don`t know what the number is. It need not be tinted.
Andrew Mace
toysrrus
toysrrus
Hi Andrew,
Your correct; They are the "576". I had mine professionally tinted just the other day & look great. I simply want a matching "LENS ONLY" for the "DRIVING LAMP" that I currently have. Both my lamps are mounted & are "Non-Functional" as I`m using them for cosmetic purposes only.
So; A "CLEAR" Driving Lens is just fine "With or Without" wiring. I don`t need or want to buy the whole entire Lamp; "JUST THE LENS"!! If anyone has one out there; Please let me know.
Thanx Again,
Russ
Got_All_4
I've been meaning to post a similar question. I have a reproduction set (Victoria British) and one of the lenses got cracked. anyone know if they are exactly the same size as originals? Seems there are no replacement lenses out there for them. You need to repurchase the entire fixture. That might be a cheaper option for ya Russ. In the mean time I looking too but for a cheap one.
toysrrus
toysrrus
Hi There Got_All_4,
I`m not going to spend several hundred $$$ for a complete "Repro" Fog Light Ass`y! I already have "Both" & mounted on my car. One is a "Driving Lens & the other is a "Fog Lens". I simply like the look (Appearance) of the "Driving Lens" & would like to have a matched set (Repro or Not).
Should You come across one in your search; Please let me know & I`ll do the same.
Happy Hunting.
Russ
toysrrus
toysrrus
Found them; Both "Driving & Fog Lens` only"!!
You can get them at "jollyrogersmotors.com" (aka-noslocaters) out of Mass. (413-259-1722). Lots of "Lucas" stuff!!
I ord. a pr. of "Amber Turn Signal Lens" from them & left a msg. that I want to add the "SLR 576 Driving Lamp Lens Reflector" for $51.00 + Shipping.
Happy Motoring,
Russ
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
Editor_Reid Need Lucas Driving Light Lens Austin Healey 7
bighealeysource Mounting of Lucas driving lamps on BT7 Austin Healey 3
O Lucas Driving Lights - ID help MG 13
Alan_Myers Lucas driving lamp covers Triumph 1
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
