Delayed charging Lucas alternator
badornato
My TR3 has Lucas Moss neg ground alternator with two wires. Brown output and a yellow/green indicator wire. For the past year, on initial startup there was a delay in charging (red light going off and positive amps on the meter) ONLY on first startup in the am. (but car always kept in warm garage so not temp sensitive). Delay was variously 10 or 15 seconds to 60 seconds usually terminated by revving up over 2000 rpm. It would not happen on other startups that day.
Now the delay is minutes, not seconds. and can occur at every startup. What kind of electronic malfunction is this? I have checked the connections and the ground on the alternator....no joy. When the red light is on, there is only battery voltage. Light off gives me 14.9 volts.
Fan belt is tight and alternator is turning with the belt.
Should I just replace the alternator (again..only 5 y old).
trglory
Have an auto-electric shop check your alternator. Replacing a diode is a lot cheaper than buying a new alternator.
drooartz Delivery delayed MG 13
R Delayed Hello from a new member MG 11
S Delayed intro Spridgets 5
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
I Bugeye charging issues Spridgets 8
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
N Charging warning light LED conversion Austin Healey 29
K TR2/3/3A Alternator not charging? Triumph 2
M Alternator not charging Austin Healey 0
D BJ 8 not charging !! Austin Healey 6
L Ignition / Charging light wiring Austin Healey 3
D Charging issue on mk1 British Motor Corp 1
M TR4/4A Charging system question? Triumph 6
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
dklawson Spitfire Supositions Wanted - '72 Spitfire Charging/Not-Charging Issue Triumph 5
M Charging Optima Batteries Jaguar 5
David_DuBois Off Topic How about terbo charging? MG 7
angelfj1 Charging System Failure Triumph 28
I Help on charging system please Spridgets 3
doates Spitfire Spitfire Charging Issues Triumph 9
6 stumped...engine charging...or not Triumph 12
F Over-charging Austin Healey 15
O TR2/3/3A TR3 Generator Not Charging Triumph 3
T TR4/4A TR4a charging issue Triumph 15
MGTF1250Dave Battery & Charging System Question Triumph 3
6 Charging System Question Spridgets 3
eschneider Charging system possessed...... Other Cars 4
D Charging Issue....still Triumph 14
vping Not charging MG 7
GBRandy Wedge TR8 Charging Voltage at 15.9 Triumph 68
C charging problem at 3500 rpm Spridgets 6
P BATTERY CHARGING MG 3
VelodromeRacer Charging system? Racing 1
athenssprite not charging Spridgets 3
jvandyke how to read a volt meter charging? Spridgets 27
Dave Richards Generator not Charging? Austin Healey 14
bmurphy7369 XJ6C charging issue, where to start on Diagnosis Jaguar 5
B MGA charging voltage for mga generator MG 7
AUSMHLY Is my Generator charging? Austin Healey 5
S Battery charging Triumph 7
VelodromeRacer Running without a charging system Racing 22
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
T MGB Multiple charging system issues: 67 MGB MG 11
B Charging/Battery died + Tach & Idle questions Spridgets 9
MadRiver More charging questions Triumph 2
Simon TR4a Not charging! Triumph 1
Z Charging/Dead Battery Problem Spridgets 8
ronzet MGA MGA Charging system MG 7
