So I've put some of my projects on hold and had the opportunity to work on a '65 for some extra change. Started with an engine build and now I'm finishing his restoration. Anyway....
I converted to Negative ground as per specs.
Coil wires swapped - Check and I added a Pertonix
Fuel pump - Wound up putting in a Facet as his was pos. and kinda old.
Battery cables swapped - Check.
Polarized the Genny - Check
Tach - Cut and reversed white wire loop. Swapped green wire and resistor wire - Check
Starts and runs great (re-set up carbs and gave it a tune up
So I take it out on about a 30 mile round trip, get back to the driveway and it's dead. I charge the battery, start it up and let it run. She dead again.
Problems so far - Tach is not working and Owner states it was. Shame on me for not documenting it before I started the job. Part of finishing up the restoration, was to put all the gauges back in the dash and finish the wiring. Everything works which is a good thing. Three wires not connected. A brown which is not hot, a white which is not hot and a yellow (OD wire). Both of these brown and white wires are up behind the tach.
Where do I begin? Could it be the regulator? Is my belt too tight on the Genny?
