TR4/4A Charging system question?
mtlman8
I was driving yesterday and I noticed the amm meter pulling pretty hard. The temp and fuel gage dropped, not all the way, so I thing it had some voltage but not full. I got home and turned the car off and it would not restart, Dead battery... The battery is known good and the car has the altenator conversion. I don't see any loose connections. Thoughts?
TR3driver
Great Pumpkin - R.I.P
Can you be a bit more specific? What did it read, under what conditions?
Was the alternator wired so the ammeter accurately indicates charge? (Many directions say to wire the alternator directly to the battery, so the ammeter no longer indicates charge.)
Kinda sounds like a bum alternator and you just drove until the battery ran down.
M
mtlman8
The ammeter seems to work correctly. it was reading about 15, but it would move rapidly from 0 to 15 and back and forth.
trrdster2000
John, First off jump the car to start, carefully. Then check the voltage on the terminals, should be 13.2V to 14.1V, if not, your alternator has a problem with the voltage regulator or field.
Did you do the connections under the old regulator, if so I hope you used soldier.
Wayne
trrdster2000
John, with that sort of action, you have a short somewhere. The reading should be very even at a constant RPM. The alternator has a regulator built in and that can give this sort of jumping around.
Wayne
M
mtlman8
The connections are crimped and taped, not soldered. The new ones will be soldered once I figure out the problem.
pdplot
I had a similar problem years ago with a used 1952 Ford that I just bought. On the trip up the Jersey Turnpike to show my folks, the lights grew dimmer and the electrical system was failing. I made the rest area and while I had dinner. the mechanic on duty checked the car out. Dinner over, I went back to the garage and was told the problem was fixed. How much? Nothing. He hit the voltage regulator with a wooden-handled screwdriver and cured the problem. I offered him $10 and he refused. I suggest you try the same. I never had a problem in the two years I owned that car which was traded even up for a '52 MG TD - my first sports car.
MGTF1250Dave Battery & Charging System Question Triumph 3
6 Charging System Question Spridgets 3
M Newbie question about charging system Spridgets 9
C Charging system-stupid newbie question Spridgets 63
angelfj1 Charging System Failure Triumph 28
I Help on charging system please Spridgets 3
eschneider Charging system possessed...... Other Cars 4
VelodromeRacer Charging system? Racing 1
VelodromeRacer Running without a charging system Racing 22
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
T MGB Multiple charging system issues: 67 MGB MG 11
ronzet MGA MGA Charging system MG 7
Coleman Charging System Triumph 0
H Charging System Problems with Sprite Spridgets 8
S TR4/4A TR4A Charging system Triumph 6
rick_ingram MGC Charging system woes - MGC MG 11
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
I Bugeye charging issues Spridgets 8
B Delayed charging Lucas alternator Triumph 1
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
N Charging warning light LED conversion Austin Healey 29
K TR2/3/3A Alternator not charging? Triumph 2
M Alternator not charging Austin Healey 0
D BJ 8 not charging !! Austin Healey 6
L Ignition / Charging light wiring Austin Healey 3
D Charging issue on mk1 British Motor Corp 1
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
dklawson Spitfire Supositions Wanted - '72 Spitfire Charging/Not-Charging Issue Triumph 5
M Charging Optima Batteries Jaguar 5
David_DuBois Off Topic How about terbo charging? MG 7
doates Spitfire Spitfire Charging Issues Triumph 9
6 stumped...engine charging...or not Triumph 12
F Over-charging Austin Healey 15
O TR2/3/3A TR3 Generator Not Charging Triumph 3
T TR4/4A TR4a charging issue Triumph 15
D Charging Issue....still Triumph 14
vping Not charging MG 7
GBRandy Wedge TR8 Charging Voltage at 15.9 Triumph 68
C charging problem at 3500 rpm Spridgets 6
P BATTERY CHARGING MG 3
athenssprite not charging Spridgets 3
jvandyke how to read a volt meter charging? Spridgets 27
Dave Richards Generator not Charging? Austin Healey 14
bmurphy7369 XJ6C charging issue, where to start on Diagnosis Jaguar 5
B MGA charging voltage for mga generator MG 7
AUSMHLY Is my Generator charging? Austin Healey 5
S Battery charging Triumph 7
B Charging/Battery died + Tach & Idle questions Spridgets 9
