Help on charging system please
ichthos
I apologize in advance if I am re-asking some of my questions for my stock bugeye. I am still working out the bugs on my bugeye as I drive it more and more. My current problem involves the charging system. The battery is new and will easily hold a strong charge even when sitting for two weeks. The starter is NOS and was checked out by a local shop. I have been driving a lot over the last few days and have had the lights on the whole time. I noticed that on the third day,the battery had run down enough where it was difficult to start. I am suspicious of the voltage regulator, but how do I tell if it is working correctly? Is this just a matter of adjusting the voltage regulator? Any help is greatly appreciated.
Kevin
Sarastro
There is a standard, easy procedure for checking the regulator's adjustment that is listed in the shop manual and in the Haynes manual.
It may be just fine, though. These old-fashioned regulators actually don't work very well, especially with our cars, which might use modern headlights, that use more current than the original, or have other additions that use more power. My car never kept the battery very well charged, even though the regulator passed all the standard tests. In fact, I installed an ammeter, and noticed that the charging system could not keep up with the electrical demand when the headlights were on. I did have an electronic ignition and fuel pump, so maybe it might just barely have kept up without those--but probably not.
I just kept a good-quality, intelligent charger around and recharged the battery with the charger occasionally.
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
