MGB Help getting my 1980 MGB to pass CA smog test
JohnGone
Member
I could use some advice for preparing my 1980 MGB (new to the state) to pass the CA Smog test. I am in the SF Bay Area. Is these a shop, freelance mech or others that specializes in this?
JohnGone
JohnGone
Member
Here is my new (1980) MGB in red on the back of the trailer to San Francisco. The truck driver said he had two inquiries about buying the car on his was across country.
Now that Thanksgiving is over I can start to focus on getting this car properly equipped. At some time in the cars history the smog gear was removed and a nice Edelbrock carb was installed. But now it is time to get this baby able to meet or exceed CA emissions standards. Any help sourcing parts, and shop referrals much appreciated.
Grantura_MKI
Good luck. You need to find someone who removed all the smog off of their 1980 to help. Some bits are NLS like most hoses, etc.
How much is missing?
JohnGone
JohnGone
Member
I am thinking I need to connect with a mechanic / shop who has done this a few times (recommends gladly accepted), then take the list from the shop manual and start scouring junk yards across the states. Or buy a complete kit from a member this list... if there is one available.
Grantura_MKI
Not all that easy, as you need a certain carb to make it Cali legal. I have removed may smog systems in the past as the car where exported. All parts long gone.
Keep in mind the California does not want you car here.
Good idea and that’s what I suggested will be the easiest route for you.
JohnGone
JohnGone
Member
Darth, I am not clear on your message. Are you saying what I want to do is next to impossible because these parts are all gone, and the best route is to sell the car out of CA?
Grantura_MKI
You need carb number C3851 for starters. Manifold, cat, vapor recovery,etc.
Order a Moss Motors catalog and it will show what’s required.
Look on flea bay for a start.
JPSmit
Message sent
JohnGone
JohnGone
Member
Thank you for the specific carb number. I am shopping for it, the manifold and some of these many items starting today.
Platinum
Had the devil's own time trying to convince Florida Inspectors the "box" in the Alfa Spider's exhaust was a cat converter on the last of the inspections. It always involved "higher-ups" at the station, consulting manuals 'n such. Finally got a passing conclusion after much back-and-forth discussion. And the tailpipe sniff was never an issue! Glad they did away with those "inspections" here.
YakkoWarner
I had 1 inspector in Virginia give me a solid run-around on many things - they actually measured the distance from the edge of the dashboard to the glass claiming the state had a minimum spec that it had to pass (and what did they expect me to do if it didn't - move the windscreen?). They also wanted to fail me because the brake lights didn't operate with the key off - it took producing a copy of the factory wiring diagram and getting someone who was able to understand it to acknowledge that it was built that way from the factory.
mezy
Reading all this makes me realise how lucky we are in the UK when it come to historic vehicles,
Pre 1982 vehicle no longer need an MOT test for road worthy, although some owners still do have there cars tested,
the MOT includes an emissions test but does not have to be as good as a modern car,
Theres is no road tax to pay as they are exempt.
Platinum
That was either sportscar envy or "ferrin car" dislike. We lived in Hampton, VA for three years, 1970~'73, had my '66 B, a B-GT and the Elan with VA tags. Back then it was more of a"safety inspection": Brakes, lights, wipers and tire wear. The MG's were never an issue but the Elan confused the heck outta them. "It's too SMALL!" was one response. :LOL:
JohnGone
JohnGone
Member
Found a very clean ZS carb and a donor, found two manifolds (I may have a spare soon), EGR valve and assorted bits. I still need the Air pump assembly. I am still a way from completion. I will post progress once we start unbolting, and bolting.
JPSmit
sounds great and yes, keep us posted.
AngliaGT
Not sure if they still do this,but when I lived in California,
I'd have them do a "pre-test" to see if it would pass,before doing
the actual test.That way,if it fails,it isn't on the record.
equiprx
Many years ago in New York, inspection required at least one windshield wiper, BUT didn't require a windshield.
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
Tr3aguy TR2/3/3A Help getting back on track.....TR3 Triumph 6
Tr3aguy Finally getting round to it....help! Triumph 2
C Getting frustrated: no spark, please help Triumph 18
J Best tool for getting help in the garage. Restoration & Tools 13
Schroeders Suggestions / Help Getting at the Temp Gauge Plug Austin Healey 9
J More help on getting stuff off for painting-- Triumph 5
J Need help getting rear fender off Triumph 8
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
