BATTERY CHARGING
POJOKIP
NEED HELP ON HOW TO CHARGE THE BATTERIES ON MY 1974 MGB-GT. DO I CONNECT THE POSITIVE CABLE TO THE POSITIVE TERMINAL ON THE PASSENGER SIDE BATTERY AND THE NEGATIVE CABLE TO THE NEGATIVE CABLE ON THE DRIVER SIDE BATTERY? IT'S BEEN A VERY LONG TIME SINE I'VE NEEDED TO DO THIS AND WILL APPRECIATE ANY HELP. THANKS , GUYS.
davester
That would work, but to avoid screw ups, It is best to connect the positive to the positive on the passenger side battery and the negative to a ground.
BTW, ALL CAPS drastically reduces readability and is also considered bad internet form.
Unless you are a stickler for originality, I suggest making the change (when needed) to a single 12v battery (size Group 26) placed into the passenger (right side) of the battery boxes. You can then get a bin to place in the left hand side box to create additional storage.
Platinum
Actually, it's consider'd <span style="color: #FF0000"><span style="font-weight: bold">~SCREAMING~</span></span>...
Disconnect the ground to the chassis and connect the positive to one battery, the negative to the other.
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
MGTF1250Dave Battery & Charging System Question Triumph 3
S Battery charging Triumph 7
B Charging/Battery died + Tach & Idle questions Spridgets 9
Z Charging/Dead Battery Problem Spridgets 8
B Converted to Negative Ground - Battery charging? Austin Healey 17
mbrooks Battery charging during storage Austin Healey 5
R6MGS Battery/Charging question Triumph 7
gsalt57tr3 Wedge TR7 alternator not charging the battery Triumph 2
N Pos Ground...Battery Charging? Austin Healey 14
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
