Battery Cable Specs
Da bigga da betta ... that's a long run to the solenoid. IIRC, we used 00 welding wire for my BN2. Also, the connection to the terminals is critical; either solder or a proper crimp.
Keoke
I agree 100% the welding wire is also very flexible.
Michael Oritt
As with everything there is a debate as to which--batter cable or welding cable is "better". There are pro's and con's with each. FWIW I have always used battery cable on any boats or cars--including my race cars but that's just me. In any case be sure to use high-grade terminals either soldered or staked and well insulated, harnesses, clamps, etc. so you don't have any issues with chafing.
DarvinR
Great to hear welding the wire is recommended here. We'll just finish installing the suspension from 4Wheelonline onto the Jeep Wrangler and we'll start working on buddy's new BN6 project.
Michael Oritt
Darvin--
Just because some members use welding cable does not mean it is recommended or your best choice. Before deciding between battery or welding cable I would suggest that you spend an hour googling about and make your own decision on what is best for you. Bob S. is a pretty smart guy and he must have his own reasons for using it. I think I am pretty smart too and I only use battery cable, even on my race cars where weight is an issue.
Invest some time and form your own opinion.
Jake
What's the load your solenoid pulls? You'll need to know that to properly size the cable. You can always overshoot, but why not do it right?
See if you can find a copy of SAE-J1127, good info in there about low voltage battery cables.
... Bob S. is a pretty smart guy and he must have his own reasons for using it. I think I am pretty smart too and I only use battery cable, even on my race cars where weight is an issue.
My dad bought the welding wire; I had no input on his decision (we also used solder-type terminals, and had to use an oxy-acetylene torch to get good flow on the wire). I agree research is called-for; I'd be curious about the pros and cons myself. The welding wire is pretty stiff; maybe battery cable is more flexible? Both types are used in applications where current is significant, and voltage drop is not desirable. I know cheaper jumper cables can get hot with much load (I have a battery load tester with small cables, and I can only use it for a few seconds before the cables feel like they're about to melt).
Keoke
What's the load your solenoid pulls?:
-What in da world does this have to do with the load on the battery cable.---????
Jake
Ah, bad question on my part, I read solenoid above. How about this as a more general question?
What's the max current load expected to be drawn through this cable? Length is already stated at ~6ft. The load is going to be a key parameter if you don't want to oversize/undersize the cable.
Jake
A general rule of thumb is 1 amp starter draw/1in3 of engine displacement. BN6 is approx 161 in3 displacement. You also need to add your ground cable length to get the total cable length for sizing. 2AWG is rated for 150 amps over 10' with a 2% voltage drop, just FYI.
Also go for solid copper rather than CCA if you have a choice.
Keoke
Jake :
You makin DR OHM's cry in his grave.--LOL
Keoke
GregW
Platinum
What about soldering up copper plumbing pipe and coating it with tool dip? Then it could double as the fuel line.
Keoke
:bananawave: YEAH !
Hmmmmmmmmmm ... dunno about that. I was fabbing some brake line on my BN2 and while fitting I touched the line to the neg. terminal on the two batteries (those burns got a LOT uglier before they got better, and took weeks to heal):
sparkydave 1500 battery cable colors Spridgets 1
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
M TR2/3/3A TR3 Battery cable Triumph 9
Rob Glasgow Lucas Battery Cable Helmet Connectors Austin Healey 11
RAC68 Request Battery Cable Length Austin Healey 3
vette Battery Cable Clip Location Austin Healey 19
NutmegCT TR2/3/3A TR3 battery ground cable Triumph 8
Superwrench Battery cable Austin Healey 8
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
P Battery cable?? British Motor Corp 5
T TR2/3/3A TR3 - positive earth cable from battery is hot Triumph 2
davidk TR6 Negative Battery Cable on TR-6 Triumph 9
chicken Battery cable routing in boot Austin Healey 4
sparkydave Battery cable colors Spridgets 9
H How Does Battery Cable Connect to Shut Off Switch? Austin Healey 21
Team_Sprite Wanted: "Helmet" type battery cable ends. Spridgets 4
M 100-6 Longbridge battery cable route in trunk. Austin Healey 0
AUSMHLY Grommet in rear battery cable panel Austin Healey 1
F BATTERY CABLE [fried petronix] Austin Healey 20
F battery cable Austin Healey 9
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
