fordhealey
upon replacing my battery cable, i found a small bare spot
where the cable had rubbed against the body.i'm guessing that is the reason that i fried a petronix ignition previously. it wasn't making constant contact, but i
believe the result of it grounding resulted in the meltdown (literally) of the module.it was well worth the expense of
replacing the cable. it saved the expense of replacing the new module, an solved the mystery of the meltdown.(not covered by the warrenty!!)
gregg
gregg
