New Battery Needed for BJ8
Daniel Kaminsky
I needed a new battery for my BJ8 so I traded in my Interstate, but so far they have not been able to provide me with the same model. Does anyone have an idea about another brand which would fit and be reliable? Thanks, Dan.
Gliderman8
Re: new battery?
As long as you get the same group number as the battery you are replacing it should fit exactly.
twas_brillig
I used to measure up the size of the battery base on the various vehicles we've owned, as well as the height, and just bought whatever was the biggest one that would fit in the hole - making sure the post connections would also work. Doug
British_Recovery
Bronze
Use a 27 if you have maintained positive ground, and a 27f if you are now negative ground. This keeps the posts in the original location, away from the metal hold down bracket.
Bob
gonzo
Group 27 lead battery gave excellent fit and performance for many years until the alternator / negative ground conversion. A smaller and lighter group 24F lead battery is now used. A battery tender helps keep it fully charged and conditioned.
PHulst
Bronze
If you can, find an AGM type of battery. The Platinum series at AutoZone is, I believe, an AGM made by Deka.
Then, get a battery minder made for an AGM and you're good to go.
My 100-6 has an Optima (which is AGM) that the previous owner swears was installed in 2003. It still works.
The AGM in my 72 Corvette lasted 10 years.
I put the AZ Platinum in my 2008 Corvette when it needed replacement.
Keoke
Yep a group 24 sealed is recommended
Michael Oritt
You can mount an AGM on its side, so even if you flip your car over it will not leak. Of course, you might have other concerns....
O Battery box install- advice needed! Spridgets 4
Team_Sprite Needed: Bakelite Battery tray, and two braces. Spridgets 1
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
