Solar battery maintainer?
NutmegCT
My MG garage is not near electric service, and I don't want to have a long extension cord running out there 24/7.
I wondered if anyone has used a solar battery maintainer?
There are *many* on the market these days - but I'm wondering if they have the "oomph" to keep a fully charged car battery fully charged, as well as the proper circuitry to check the voltage and not overcharge the battery. South facing exterior wall, not shaded, six to eight hours sun a day.
Thanks.
Tom M.
JPSmit
Harbour freight has them starting at $13.99
NutmegCT
NutmegCT
Thanks gents. They're certainly affordable, but I'd feel better hearing from someone who can tell me the unit they're actually using, and how it's working for them.
I had a solar car battery charger unit about ten years ago - failed after two days. Replacement was DOA. Third (same model) would output only about 1/10th of the advertised output on a bright sunny day.
Tom M.
TomMull
I have about 30 watts of solar power on my boat. It provides all the electrical power I need but my needs are very simple. I do not have a "battery maintainer" but I have repaired several of them for friends. The only failures I've seen are in the connections to the power cord. A bit of solder and they are going again. I've not paid attention to brands but I don't see and substantial differences.
I do not use one with my cars. If stored for more that a few weeks, I disconnect the battery. I'm gone for 5 or 6 months in the winter and most of the cars have enough voltage to stat when I return in the Spring but I usually charge them first.
The lack of power for a charger at your shop might make the maintainer worthwhile. I don't think you need to worry about oomph either, most are 1.5 to 2 watts which is more than adequate unless you have an electrical draw on the system. I'd disconnect it anyway.
As for output, that's a bit tricky to measure. If you have it connected to the battery, the output will vary according to the state of the battery. You'll need to disconnect the battery and measure with no load and of course use Ohm's formula to compute watts. The latest chargers are quite reliable, in my opinion.
Hope this is of some help.
Tom
NutmegCT
NutmegCT
Tom - thanks very much for the detailed comments.
I learned the hard way not to just disconnect a battery for the winter - battery went dead as a doornail. Removing the battery from an MGTD isn't the easiest thing in the world, so I'm compromising between no extension cord, and not moving the battery.
Here's what I decided on:
https://www.amazon.com/gp/product/B00B7GC50Y/
It's 2.5 watt, 12 volt. I'll connect via the accessory plug on the fascia, which is always hot. Positive ground.
TomMull
HMM. Positive ground. I hadn't considered that. There is a polarity sensitive diode in the charger that prevents discharge at night. This is over my pay grade but I guess if you hook it up pos to pos and neg to neg you will be OK. Still might be wise to disconnect the ground on the car. Maybe one of our better informed members will chime in.
Tom
NutmegCT
NutmegCT
I'm no electrical engineer for sure. I've been using my regular battery maintainer via 120v extension cord, pos to pos, neg to neg, and it's working fine, charging right up and shutting off when charged. Seems the same hookup should work with the solar charger.
Interesting point however. Basil has an EE degree, so maybe he'll share the wisdom on this.
Edit: unless I'm completely overlooking something obvious ... On these simple cars of the 1950s-60s, the charger is charging the battery, not the charging system. It's connected directly to the battery terminals (or to wires connected to the terminals, like my unswitched accessory socket) - so I don't see a problem going pos to pos, and neg to neg.
(If I'm wrong, I figure I'll be covered in spattered molten lead soon ...)
T.
Sarastro
Tom
Yes, just hook it up as you suggest, and it should be fine. Positive or negative ground should not matter. It's only an issue when you have a piece of equipment that is negative ground and your car is positive (or vice-versa). For something that does not have a chassis that must be grounded to the car, that's not an issue.
LarryK
Check with your local RV dealer, they use them on the RVs to do their batteries while in storage.
Sherlock The aliens have invaded! Or... solar rayce cars? Other Cars 3
Sherlock How about solar cars Other Cars 1
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
