Battery connections
Dscarson
For the last two years I have been working on my 1960 Bugeye restoration. I am using the old Lucas style battery connection. I know, bad idea, but every originality point counts. The main power connects into the negative helmet. The guidelines refer generally to an “L” shaped connector. Does anyone have a idea as what it looks like?
David
two Bugeyes
one Frogeye
T WHY do my battery connections keep corroding? Austin Healey 8
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
RAC68 Battery Powerline Protection Austin Healey 40
