Charging System Question
60Bugeyefan
I have changed out the battery and voltage regulator (pre-adjusted from Moss) this weekend. I get a consistent 12V w/ no lights but this drops to 11.5V or less with turn signal or headlamps. I tested the generator per the manual and am able to generate at least 18V at 3000 RPM. While driving on the open road I do not see the voltage ever higher than 12V and never see the ammeter above 0 but it will drop with turn signal or headlamps on. Based on what I have read online, I believe I should see the voltage of 12.6V-13.5V while driving and the ammeter slightly above 0. My next thought is to change out the brushes on the generator. I have checked continuity between the generator and regulator and it tests out fine. Any thoughts?
Billm
Look in the manual and learn how to correctly adjust the regulator- Moss is good but not always perfect.
BillM
Sarastro
Keep in mind--the generator won't put out much until you're up to about 1800 RPM, plus or minus. It probably won't provide enough current to run the car at idle; that is, the ammeter will not be in the "charge" range. But, yes, at higher speeds you should see a system voltage of 13V or so, and unless you have a lot of electrical stuff turned on, the ammeter should show at least a small charging current.
By testing the generator, do you mean that you jumpered the output to the field coil terminal and disconnected it from the rest of the electrical system? If so, I'd expect something higher than 18V at 3000 RPM. If the generator was still connected to the electrical system, though, that might be OK.
Did you check belt tightness, and make sure it's not slipping?
If you check the regulator per the manual, be sure to use a decent-quality analog voltmeter. A digital meter won't work. Oh, and on the subject of meters--if you're using one of the simple automotive voltmeters from you local auto store, it might not be working right.
M TR4/4A Charging system question? Triumph 6
MGTF1250Dave Battery & Charging System Question Triumph 3
M Newbie question about charging system Spridgets 9
C Charging system-stupid newbie question Spridgets 63
angelfj1 Charging System Failure Triumph 28
I Help on charging system please Spridgets 3
eschneider Charging system possessed...... Other Cars 4
VelodromeRacer Charging system? Racing 1
VelodromeRacer Running without a charging system Racing 22
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
T MGB Multiple charging system issues: 67 MGB MG 11
ronzet MGA MGA Charging system MG 7
Coleman Charging System Triumph 0
H Charging System Problems with Sprite Spridgets 8
S TR4/4A TR4A Charging system Triumph 6
rick_ingram MGC Charging system woes - MGC MG 11
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
I Bugeye charging issues Spridgets 8
B Delayed charging Lucas alternator Triumph 1
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
N Charging warning light LED conversion Austin Healey 29
K TR2/3/3A Alternator not charging? Triumph 2
M Alternator not charging Austin Healey 0
D BJ 8 not charging !! Austin Healey 6
L Ignition / Charging light wiring Austin Healey 3
D Charging issue on mk1 British Motor Corp 1
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
dklawson Spitfire Supositions Wanted - '72 Spitfire Charging/Not-Charging Issue Triumph 5
M Charging Optima Batteries Jaguar 5
David_DuBois Off Topic How about terbo charging? MG 7
doates Spitfire Spitfire Charging Issues Triumph 9
6 stumped...engine charging...or not Triumph 12
F Over-charging Austin Healey 15
O TR2/3/3A TR3 Generator Not Charging Triumph 3
T TR4/4A TR4a charging issue Triumph 15
D Charging Issue....still Triumph 14
vping Not charging MG 7
GBRandy Wedge TR8 Charging Voltage at 15.9 Triumph 68
C charging problem at 3500 rpm Spridgets 6
P BATTERY CHARGING MG 3
athenssprite not charging Spridgets 3
jvandyke how to read a volt meter charging? Spridgets 27
Dave Richards Generator not Charging? Austin Healey 14
bmurphy7369 XJ6C charging issue, where to start on Diagnosis Jaguar 5
B MGA charging voltage for mga generator MG 7
AUSMHLY Is my Generator charging? Austin Healey 5
S Battery charging Triumph 7
B Charging/Battery died + Tach & Idle questions Spridgets 9
